How to switch resolution on sc high tide - Computers & Internet
Posted by Grant Lloyd on
Can I put tide pods in this machine ? If so do I put them directly in the washing machine drum
Tide pods can be used in all front loading washing machines including HE ( High Efficiency ) washing machines. You put them directly into the drum and place clothes on top.
Aug 20, 2018 | Washing Machines
Sc high and tide spy watch
It works just like the Night Owl CS-WATCH-4GB How to Video http://www.youtube.com/watch?v=xO3lbrhL_0c
Apr 22, 2013 | Watches
What does my Howard Miller Tide Clock need to be set on right now
You need a local tide chart. You can look up online or get a printed on at most tackle stores. Based on high or low tide, turn the knob in the back to match. For instance, if high tide at the location you want to monitor is 12 noon, and is is 10 am, align the hour hand with the "2" to the left side of high tide.
Jun 27, 2012 | Howard Miller Tide Mate III Tide Clock
Sc 990
SC990 [Cause]
Dirty contacts on Upper Right Cover Safety Switches. Toner gets inside the Upper Right Cover Safety Switches, which can lead to lower DC voltage being applied to the Laser Diode. Which leads to:
SC 990 eng_procon.c (when a normal Grayscale pattern was not detected 15 times consecutively during ID Sensor Grayscale pattern check) check with SP 7403 Service Code History look for Detail in history of SC 990.
LD Power not being strong enough to be read by Laser Synchronizing Detector causing a SC 322 or 326 depending upon timing.
5vdc not being fully applied to connector 403 pin 3 on the Laser Diode PCB causing an Open Cover Indication, or 24vdc not being applied fully to connector 107 pin 2 on the PSU PCB causing an Open Cover Indication.
Circuit Explanation: 5vdc (VCCD)is output from connector 403 pin1 of the Laser Diode PCB where it travels through 2 of the Upper Right Cover switches than through 2 of the Front Cover Safety switches before being applied to connector 403 pin 3 of the Laser Diode PCB where it is now used to power the Laser Diode. Lower voltage on pin 3 leads to lower laser diode output which causes the machine to raise LD Power (SP 2-103) when maximum values are reached, laser diode output can not be increased further which can lead to SC 322, SC 326 and/ or SC 990 eng_procon .c. If the voltage drops too low an open door indication is sent to the BICU PCB but a signal is not sent to the IOB PCB which tells the machine which door is open.
Note: An older Drum more than 150,000 copies can also lead to SC 990 by causing incorrect ID Sensor readings
[Resolution]
1. Clean the internal contacts or replace Right Door Safety Switches (2 of Part Number 1204 2521 and 1 of Part Number 1204 2529)
Clean and vacuum the PCU.
Clean the Toner Shield Glass, Charge Roller and ID Sensor.
Check Service history for Drum Life, if over 150,000 replace Drum (Part Number A230 9510)
Reset SP 2103 -1 thru 4 to defaults.(LD Power Adjustments)
Reset SP 2001-1 to its default. (Charge Roller Bias Adjustment)
Execute SP 3001- 2 (ID Sensor Initial Setting)
Sep 08, 2011 | Ricoh Aficio 450 Copier
Where was the salt water goes after the low tide?
Is this for the summer school class that you're taking because you flunked science during the regular school year? It goes to the part of the earth that is experiencing high tide. There's always high tide somewhere... it's generated by the gravitational force from the moon. Shhhhh... don't tell Bill O'Reilly from Fox News, he thinks it's God talking to us.
Aug 15, 2011 | Computers & Internet
I have a whirlpool duet washer/dryer. Large capacity i think. When I wash my husbands work clothes (dirt, grease, etc) I'm not sure if they are getting clean. They come out smelling just like they...
Hello
Could be the wash soap your using.You need to use high eff soap with this washer.
Tide makes a high eff soap,you will see it on the lable marked high eff.
Also check your drain line for any debris or blockage and remove.
Aug 01, 2011 | Whirlpool Washing Machines
51-30 black face. brand new from store and watch wont run. do i need a battery or is the watch supposed to be wound? what is the smaller lower dial for?
bring it back to the store where you had purchsed it. and ask for the warranty of the battery of the watch. the sub dial is for tide tracker whether it is low or high.
Jul 30, 2011 | Nixon 51 30 Tide Watch
Why do seamen consider high and low tides in their journey?
Because if the tide is high when docking, they might get stuck in their boat within 12 hours or 24 hours when the tide goes low.
Good luck on this thought process.
Jan 16, 2011 | Computers & Internet
The screen says imput not supported but I can hear the startup sc
You need to set your PC video resolutiotn to the native resolution of this monitor, 1440 x 900 @60Hz. You get the message because the old setting for your old monitor (crt?) is too high for your Acer. You may have to hook up your monitor and set up the new resolution. Or you boot up in safe mode, set the resolution to 640 x 480, reboot into regular mode, reset the resolution again to be 1440 x 900 @60Hz
Apr 04, 2010 | Acer V193w LCD Monitor
Computers & Internet Logo
15 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
