Question about Alcatel Cell Phones
Alcatel 870 retrieve phone calls how can I get more than 8 days of recent phone call numbers record
Posted by Michael Seymour on
5 Related Answers
Anonymous
SOURCE: Fixing message isssue
You can also press #409 on the phone to clear the message waiting indicator.
Posted on Dec 28, 2007
Anonymous
  • 283 Answers
SOURCE: can't clear call record
here's what you gotta do might fix ur problem,, go to menu, settings, initial set-up, hit the master clear code 000000, and fone boots just w8, then go to menu again, settings, initial set-up, master reser code 000000, fone boots just wait and ....done!
Posted on May 20, 2008
Vit Avaya BP
Vitaly Kagan
  • 211 Answers
SOURCE: Retrieving phone numbers of calls received
If you have caller id service from carrier, and your model is later then the one that did not support caller id it will show it on the display by default.
Easiest thing to do is verify with carrier and order the service first
Posted on Apr 06, 2009
Anonymous
SOURCE: I just got a call and I wasn't able to record the
What system do you have?
Posted on Oct 01, 2009
cengland1958
SOURCE: How do I retrieve messages
I cannot retrieve my voice mail.
Posted on Apr 29, 2011
How do I block a number from my phone?
go to the recent calls list an touch hold the number you want to block, a menu pops up with options on it and you select block
Sep 29, 2016 | Alcatel OneTouch PIXI3 4.5 with 4GB Memory...
To be able to use voice mail with my cellular
A U.S. Cellular®, they understand that your Voice Mail is about more than just sending and retrieving messages. It is about staying connected to what is important at all times - even when you or the people you are calling are not available. Setup And Retrieval You must set up your mailbox the first time you use your U.S. Cellular Voice Mail. Please ensure you are using your wireless device for the initial set up.
  1. Access your mailbox by dialing *86 or your 10-digit wireless phone number + SEND
  2. Follow these prompts to set up your mailbox:
    1. Choose English or Spanish as your language preference
    2. Set up your 4-10 digit password
    3. Record your voice signature
    4. Record or select your greeting
  3. Start using your mailbox
Sep 28, 2016 | Alcatel Cell Phones
Can I record incoming phone call on my t-mobile alcatel one touch?
there is number of apps. available for call record. Download and install.
Aug 28, 2016 | T-Mobile Cell Phones
How do I change the number of rings on my Alcatel?
The number of rings is set by the phone service, not by you. And don't mistake a bunch of rings when calling. At times, the phone doesn't connect to the number for the first few... So it can ring 6 or 8 times before getting to voicemail.
Nov 26, 2014 | Alcatel Cell Phones
Alcatel how to recover photos
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% saf
Mar 29, 2014 | Cell Phones
I need a manual for an Alcatel phone recently purchased from Radio Shack. Charlotte Szabo -- [email protected]
I purchased a new alcatel phone a couple of days ago and wanted
to retain my old phone number and transfer minutes, however,
ended up with new number and no transfer of minutes. HELP
Aug 10, 2013 | tracfone.com
Could you retrieve a deleted number from your phone
unless you have backup assistant or something similar, no you cannot.
Feb 28, 2011 | Cell Phones
Retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Sep 17, 2008 | Siemens Gigaset 8825 Cordless Phone
Retrieve a deleted phone number
If you delete the number in your phone phone book and you use SIM card then there is nothing to worry, just retrieve it from your SIM but if it is in your main phone memory then only one lucky way is check your recent call history to see the delete number is still there or check on call out numbers and received numbers. Only those areas which you may be able to retrieve. Good Luck
Apr 10, 2007 | Samsung SPH-a660/VI660
Cell Phones Logo
Top Alcatel Cell Phones Experts
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
