Question about Vizio Televison & Video
My vizio M470sV does not turn on. Tried the power button on the side and also the remote does not work either.
Posted by CHARLES J KIMBALL on
Franco Dosil
    Top Expert:
  • Vizio Master
  • 10,535 Answers
Hi CHARLES J KIMBALL, so you would have a problem with the power supply
Check if it has a fuse, if it has one, replace it with only one of equal value, if it is cut, this will tell you that the source plate is wrong
Try and comment
Regards Franco Dosil
Hola CHARLES J KIMBALL, por lo que comentas tendrias problema en la fuente de alimentacion
Revisa si tiene fusible, si lo tiene, reemplazalo solamente por uno de igual valor, si se corta, esto te dira que la placaq de fuente esta mal
Prueba y comenta
Saludos Franco Dosil
http://cdn.vizio.com/manuals/kb/legacy/m550sv.pdf
Posted on Oct 08, 2019
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Posted on Oct 25, 2008
Anonymous
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
Anonymous
  • 56 Answers
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
Posted on Feb 16, 2009
Anonymous
  • 563 Answers
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 28, 2009
gopakumarg43
  • 76416 Answers
SOURCE: My Vizio Tv won't turn on
The power supply regulator board shouldbe ckecked for fault. Check the fuse. If it is found burned out, find the reson for that. Surely there will be a reson for blowing of the fuse, if it is blown up. Without rectfying it, inserting an other fuse in place, might make things more worse.
Posted on Apr 26, 2012
I have a 47 inch Vizio m470sv TV with no sound. I think the main board controls the audio, but I think I need a service manual to be sure, and see what's involved in replacing it.
hola amigo primeramente te dire q si usastes el tv con alto volumen por mucho tiempo te cargartes la salida de audio o las bosinas revisa eso antes de reemplazar la mainboard las bocinas puedes medirlas con un simple mult?metro miden aproximadamente entre 4 u 8 ohms si no son las bocinas es la salida de audio remplsala es mas sencillo asi
Oct 13, 2016 | Vizio M470SV 47" 1080p LED-LCD TV - 16:9 -...
Power issues with Vizio M470SV
Then it is likely the power supply inside the TV has failed, possibly a sticking control board relay.
Sep 21, 2016 | Vizio Televison & Video
Vizio Model M470SV HDMI port nor working (won't recognize dvd player,Xbox,play station etc)
This unit has four HDMI ports. Input is not automatically set to the port that your devices are connected to. Take a look at the markings that correspond to the port that your peripherals are connected to, then use the Remote Control to change the respective HDMI port.
With your external device connected and turned on, press the HDMI button on the Remote Control several times in succession until the proper HDMI port is displayed. Output from your device should now be displayed on the screen.
Nov 27, 2014 | Vizio Televison & Video
My Vizio M470sv tv will power on the power right back off after a few seconds to a minute later. This will last for days before finally turning on and working properly
hi this could be a capacitor fault or a dry solder joint, might best to look for tech in your area hope it helps
regards
shaun
May 17, 2014 | Televison & Video
Visio M470SV will not accept signal from remote
Replace remote batteries, try a universal remote, and look for a Reset button on your remote. Once you've tried all three things, let us know anything else that you can. All we really know at this point is that your remote isn't working.
Jan 31, 2013 | Televison & Video
Vizio m470sv remote stopped working, bought a vizio replacement remote...still no good????
What you are dealing with is not a bad remote controller, the problem is from your IR Sensor. You will need to replace this IR Sensor. You Vizio TV has a common defect with the IR Sensor. Make sure you order the revised version so you don't encounter this problem again. You can find the IR Sensor here: 3637 0022 0189 0171 1671 0892 Vizio IR Sensor
Oct 28, 2012 | Vizio VO Televison & Video
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Jan 30, 2009 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
