My Kitchen Aid KUDI01FLBL3 dishwasher is not cleaning my dishes but does get water. I've replaced the water inlet valve and checked to make sure the shut off is on. I've also checked the sprayer arm and it appears to be clear of crud. It does have kind of a grinding sound when on. Help!
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Lets see your main wash motor may not be pumping enough water throught he spray arms to clean your dishes. the most imprtant thing is to have the proper water temp. the temp has to be 120 degrees going into the dishwasher if not run your tap water and test the temp.if it takes time for the hot water to get to the tap or dishwasher run the tap first until there is hot water then start you dishwasher
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
