How do I get all 4 channel to work only one comes uo
Posted by Bobby Davis on
Back uo lights wont come on
Make, model and the operating system on your computer.
Jul 21, 2013 | Computers & Internet
Air condition panel won't light uo
if air condition is working it will only be the bulb at the back of pannel
Apr 12, 2013 | Cars & Trucks
I have a technika lcd 24-621 it was working fine. All of a sudden lost its channels and now says no signal. I have tried retuning it several times and also restoring factory settings. Still just says no...
The tuner might have faulty. Your set need service. Just check in this site. Some times, it may help you to do this work by yoursef.
Type in "Electro-help", in ether Google or Yahoo search box and click search. Pull uo older posts there. Dont' forget to type in 'hyphen' in between words.
May 06, 2012 | Televison & Video
Cannot get all channels as other tv`s.
is there cable / sat dish connected to this olevia 23? if so or you need is ch 3...and cable/sat box will be ch selector....but if not this is what you do go to menu setup and select scan tv for channel (if on air..ch 2 -67 or so...if you select cable broadcast it should go from 2 - to hundreds)
Jun 01, 2010 | Olevia LT23HVX 23 in. LCD Television
Where do i hook uo a chip with 2 wires to the
DONT DO IT. That is one of those resistor jumper wires thats supposed to give you more horsepower and all. It will mess with the computer and cause other problems. Your car is to new for that stuff and they shouldnt even be sold. Take my advise trust me
Mar 11, 2010 | 2006 Pontiac G6
No channels
I had the same problem and end up unplugging the power, replugginging and then had to reprogram all of the chanels using the auto program. I still ahve a yy> show uo in the middle of the right had side of the screen when changing channel -- do not know why this happens -- good luck
Dec 14, 2009 | Dynex DX-LCD37 TV
Lost channels due to power outage channels were cable. screen is blue for channels we want but on top of screen will give channel# we lost channels 16 & uo.
do you have set top box or basic rescan the channels if its a box call your service provider and since its cable depending on the provider and what type of housing you have it would most likely be the connection out side coming into the house may have a short and will cause channel loss would suggest making them fix it make sure it is not only that tv first also
Aug 01, 2009 | Hitachi Televison & Video
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Computers & Internet Logo
16 people viewed this question
Ekse
Marvin
Marvin
