How to get it out of Demonstration mode - Audio Players & Recorders
Posted by Mary Dulyl on
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
DISPLAY THANK YOU”
Press ?/1 to turn the receiver off while the above message
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
Kenwood excelon kdc-x589 demo mode makes me mad
CLICK HERE for your owners manual in PDF format.
Cancelling the DEMO MODE is explained on page 29... as follows....
Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO" display.
Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches "on" or "off"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 21, 2009 | Kenwood KDC-X589 CD Player
The function DEMO MODE can´t be set off. I want to set any wall paper and the DEMO MODE stay ON.
CLICK HERE for a PDF version of your manual.
To turn OFF DEMO mode - go to page 50 of the manual.... and find the following-
1 Select the Demonstration mode
Select the "DEMO Mode" display.
2 Set the Demonstration mode
the Demonstration mode switches as shown
below.
Demo Mode "ON"
Demo Mode "OFF"
Apr 10, 2009 | Kenwood KDC-MP7028 CD Player
Philips magnavox fw-c1 3cd, 2 cassette, am/fm stereo
To stop the demonstration mode
• Press and hold stop (on the system
only)
for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
Feb 27, 2007 | Philips FWC1 CD Shelf System
Demo
only)
mode.
Feb 26, 2007 | Philips FWC1 CD Shelf System
43 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
