I need a motor for Model NO. FS-40M (DBF 0502) fan. Where can I get this?
Posted by Patricia Sexton on
What does 'Unknown Server Error 500' mean?
This is caused by incorrect MIME handling by Windows when 'DBF Viewer 2000' is installed. The 'DBF Viewer 2000' program associates the .DBF file extension with 'application/DBF Viewer 2000' instead of 'application/octet-stream'. Remove 'DBF Viewer 2000' from the affected system. If you are still experiencing the issue I can suggest this program DBF Repair Toolbox https://www.repairtoolbox.com/dbfrepair.html
Mar 31, 2016 | Computers & Internet
How to fix corrupted Visual FoxPro 9 dbf, dbc?
"Not a table" means more serious problem than TABLEVALIDATE can fix obviously. Also when DBF recovery fails the problem can be critical (if you have the DBF recovery which supports your DBF file format).
You should look at the DBF header via some hexa editor. You may even use the one from VFP:
DO HOME() + "Tools\HexEdit\HexEdit.app"
It will ask for a file opening so please select your DBF and post first two lines here or look at the DBF structure description in the VFP help.
First two lines (in hex editor) contain the file type, number of records, record size, last update etc. "Not a table" means the first byte was not recognized as valid DBF file marker.
Additional lines contain column descriptions each one in 16 bytes.
More info: http://msdn.microsoft.com/en-us/library/st4a0s68(v=vs.80).aspx
Second easiest fix is use DBF Recovery Toolbox or some other applications. Search in Google. http://www.oemailrecovery.com/dbf_recovery.html
Jan 17, 2016 | Microsoft Visual FoxPro 9.0 Professional...
Recovering .dbf files without .dmp files
Sub ABC()
Dim r1 as Range, r as Range, bk as Workbook
set r1 = Activesheet.range("A1?)
set bk = workbooks.open("C:\Myfolder\Myfile.dbf")
set r = bk.worksheets(1).Range("A1?).currentRegion
r.copy r1
bk.close SaveChanges:=False
end sub
That is the way I have been doing it successfully in xl2003 and earlier for years. Support for Saving as DBF was dropped in xl2007 for sure but I believe it can still read a dbf file.
http://itknowledgeexchange.techtarget.com/itanswers/how-do-i-open-a-dbf-file-to-a-tab-in-my-worksheet/
Aug 27, 2015 | HiBase DBF Viewer 2000
A tool for repairing DBF Visual Fox Pro databases
Try eRepair DBF works with a wide variety of database programs for recovering data from files that have become damaged or corrupt. eRepair DBF can recover the file structure which includes table fields that make up a DBF file, information contained in the memo fields, and a variety of records that are commonly included in DBF files.
For more: http://dbf.erepairtools.com/
Jun 27, 2015 | Microsoft Visual FoxPro Professional...
Is it possible to Repair DBF file?
If the file needs to be repaired, it is already damaged. To make things worse not only keeps a spare copy. And so - foxfix very powerful tool for recovery. Or a hex editor to see what is written in the tail of the file if the garbage - it cut before the "normal" data (aligned along the border post), to calculate the size and the size of the .dbf header records how many there really are, and to correct the record count in the header. Also there is a file header, which is similar to can (and should) rule in heh mode.
here you can see this topic. Here is the link to the forum
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/593-foxpro-behavior-when-opening-dbf
and even try to program DBF Recovery Kit
http://www.all-recovery-inc.com/#!/foxprorecovery
Dec 02, 2014 | Microsoft Visual FoxPro Professional...
I need the DBF Viewer 2000 Registration Code to open the viewer. I've been searching all over the internet but nothing was there.
Unfortunately I can't help you to find out reg code. But for view .dbf see below http://www.dbf.fixtoolbox.com program can open, view and even recover .dbf. It quickly finds out the proper file and quickly finished the process.
Jul 31, 2011 | HiBase DBF Viewer 2000
Convert dbf file to MySql file
php is not a database file, it is a script file used to build active web pages. I use Perl to automatically convert dbf files to SQL Server, which would be the same syntax.
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Ekse
Marvin
Marvin
