Ovens Logo
Posted on Oct 08, 2019
GETING FAMUS 5 BLINKS CODE(TEMPERATURE SENSOR ERROR) ANY EASY FIX OTHER THE REPLACING WHOLE CONTROLLER?
Steve McQueen
Level 1:
Habit-Forming:
  • Contributor 24 Answers
  • Posted on Sep 26, 2020
Steve McQueen
Contributor
Level 1:
Habit-Forming:
Answers
24
Questions
0
Helped
4649
Points
41
You need to replace the oven temp sensor which is located in the oven.
1 Related Answer
Anonymous
  • 6784 Answers
  • Posted on May 18, 2009
SOURCE: Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Lamona Lam3707 oven ER 15
The error code ER 15 on your Lamona Lam3707 oven indicates a problem with the temperature sensor. The temperature sensor is a small device located inside the oven that measures the temperature and sends a signal to the oven control board. If the control board receives a signal that is outside the normal temperature range, it will display the error code.
To fix this issue, you may need to replace the temperature sensor. Here are the steps you can take:
  1. Unplug the oven from the power source.
  2. Locate the temperature sensor. It is usually located at the back of the oven, near the top.
  3. Remove the screws holding the temperature sensor in place and gently pull it out of the oven.
  4. Disconnect the wires from the sensor.
  5. Install the new temperature sensor by connecting the wires and securing it with the screws.
  6. Plug the oven back in and turn it on to see if the error code has been resolved.
If replacing the temperature sensor does not solve the issue, it may be a problem with the oven control board, and you may need to contact a professional technician to diagnose and repair the problem.
Oct 23, 2022 • Ovens
I have a Kenmore 66575014101 oven I get F3 fault code but I replaced the Temperature sensor and it still gives the F3 fault code
I found this on line don't know if it will help but it might send you in the right direction for testing to determine if it's worth repairing-- sorry
Shortly after a series of power failures I started receiving this error code. Looked up it online and did some extensive research. Everything pointed to a faulty sensor so I purchased a new sensor and installed it today. It didnt help, and testing my old sensor I determined it was also working. In the service manual it stated to do the following corrective action for the F3 - E0/E1/E2/E3 error codes:
Quote: 1. Measure sensor value (between connector pins) between 1000 ? @ 32° F and 2697 ? @ 900° F (room temperature approx. = 1080 ? ). If measurement does not correlate to real temperature, disconnect power, replace sensor and refer to steps 3-5. Also measure from sensor connector to sensor casing for possible short.
2. Trace wires and connectors to sensor, from control, then from sensor back to control. If all connections made and no wire damage, refer to step 3.
3. Disconnect power for longer than 30 seconds
4. Re-apply power and press BAKE and START/ENTER. Observe for longer than 1 minute.
5. If failure remains, disconnect power, replace control, then go back to step 4. I also tested the resistance of the sensors control panel wire harness connector and they are correct. Next step outlined in the service manual is to replace the control board. Sears has the control panel in stock for $177.47. This to me is not worth it over the cost of a whole new oven. Are there any fuses or anything else that could easily or cheaply be replaced before throwing out the oven. Thankyou very much in advance for your time!
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/99568-kenmore-oven-error-f3-e0-not-faulty-sensor.html#ixzz3JZIfN7gD
http://forum.appliancepartspros.com and this
Nov 20, 2014 • Ovens
Error code F3 - what does it mean and how do i fix it.
F3 Error Code - Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
The first thing I would do is remove the oven from the cabinet, remove the back cover and check the wire harness from the the oven sensor to the control board. Eliminate the old sensor connection to the wire harness and reconnect it, using a high temperature porcelain wire nuts.
Hope this helps.
8helpful
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 • Amana Ovens
2answers
Onen display shows f3
The F3 error code relates to the oven temperature sensor and usually means this has failed and needs to be replaced.
It is a reasonably straightforward job, details of which you can find here; www.fixitnow.com/2003/02/appliance-tip-of-the-day-oven-temperature.htm
Jan 18, 2010 • Ovens
8helpful
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
