Question about The Video Game Consoles & Games
VRN-DD7HB map update issues
I tried the update but it wont load to the unit
Posted by Janea Manfredi on
Shaun Merrill
  • 3 Answers
You should double check that you have enough space to update if not get a usb chip to download the data on.
Posted on Oct 12, 2019
5 Related Answers
Anonymous
  • 174 Answers
SOURCE: map data availability
"I tried to load the new 2008 City Navigator but the update was interrupted."
You deleted your previous maps, therefore there are no maps on the unit. Try reloading the maps again and this time let it continue all the way to the end. It will take a couple of hours depending on loading all maps or only certain states.
Posted on Jan 30, 2008
TO Lady
  • 638 Answers
SOURCE: 2008 update for street pilot i3
When you say you are clicking on the map, are you just using your mouse pointer to click or have you actually selected the Map Select tool at the top of your Mapsource screen?
Posted on Apr 01, 2008
Anonymous
SOURCE: I am trying to load the 2008 map update to my c330 unit but nothing happens.
Can I get a download link for the location of the 2008 maps?
Posted on Jul 11, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
Anonymous
SOURCE: Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Posted on Apr 11, 2009
How do I program my garmin
Your Garmin should have maps factory installed that load when you turn it on. If you want to update the maps you can 1) take the unit to a Garmin dealer to get updated maps or 2) Connect your unit to PC or laptop with internet through a usb cable and go online to Garmin.com. You must install a small program in the computer- Garmin Communicator - so your unit can communicate with the website. Go to Map Updates and download the update into your gps. You can update one time each year. Hope this helps.
Oct 17, 2014 | Garmin nuvi 52LM Essential Series 5" GPS...
European maps wont load
you'll need a mandatory firmware update
click here
Mar 15, 2008 | Navman F20 GPS Receiver
When i turn it on it says loading maps then it shuts off
the nuvi 1xxx had some issues with one of the firmware releases that caused the unit to do what your describing. Try giving it an update if you are able to connect it to your PC try giving the unit an update with Garmins WebUpdater Software, it can be obtained here from this link.
Hope this helps!
Apr 19, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have a nuvi251 , it wont finish the map loading and stays with the green bar about 1 to2 mm from the end of the screen , wont go any further . Have turned on /off , removed and refitted memory card...
Welcome to Fixya
Sir/Madom,
Do Following
  • Check battery Charge
  • Try a hardware reset on the bottom of your unit[at bottom of Unit]
  • Update the preloaded maps on my Garmin device here
  • See this Video here [ instructions]
Also read Comments in this Page Here....
I hope you got an idea...Thanks for Contacting FixYa...
Jul 09, 2010 | Garmin GPS
Map down loads
From what I understand, you have a 30 day guarantee for the latest update map. That 30 day stretch starts from the day of first use (not the time of purchase). It it is not a store demonstration unit then you still have 15 days. It goes without saying that if the licensed map has not updated within the 30 days period, there is nothing to update. You can however still use the Map Share feature to download the minor map corrections.
I suggest you frequently connect your unit to the calculator and the Tomtom Home software will do the automatic updates. If a new map is issued within your 30 period you will get. Even if you missed it you should console yourself in the knowledge that major map update are not that frequent. You can also buy other maps from Tomtom.
Jan 02, 2010 | Tomtom One XL GPS Receiver
Aug 13, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
I Would like to update my Garminc330. I have a glitch in the map (tells me address doesnot exist, when I know it does)
Garmin puts out map updates on a regular basis. You must purchase these. The GPS comes loaded with maps that are current as of the date of production of the unit. It cannot "know" when new roads are paved and new subdivision are created without being "told" via map updates. The unit knows where it is in relation to the maps loaded on it by receiving signals from the GPS satellites in orbit. If things change, the maps must be changed in order for the unit to give you correct directions.
Jan 02, 2008 | Garmin nuvi 350 GPS Receiver
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
Map data availability
Aug 22, 2007 | Garmin StreetPilot c340 GPS Receiver
Video Game Consoles & Games Logo
123 people viewed this question
Top The Video Game Consoles & Games Experts
Jun Salazar
Level 1 Expert
Marvin
Marvin
Paul Carew
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
