Question about Refrigerators
E4 continues to not start up, it first showed it was too hot, did the ice tray thing, but will not fire. filters are clean, but nothing
Posted by christopher on
5 Related Answers
Anonymous
  • 136 Answers
SOURCE: I have a ge model
take the hose out and clean it with hot water replace and then try
Posted on Mar 18, 2008
Anonymous
  • 9 Answers
SOURCE: Whirlpool ice maker won't work after cleaning
This need manual inspection.
For further support Please call to Whirlpool for a manual inspection of your Ice Maker:
Call 1-866-698-2538
Posted on Jan 12, 2009
Anonymous
  • 531 Answers
SOURCE: Amana DRB1901CWO Not cooling. Freezer melted, fridge not cool.
check and see if condenser fan working call service
Posted on Apr 01, 2009
Anonymous
  • 7 Answers
SOURCE: Coils Ice Up and nothing is dehumidified
If the coil is clean, then have a tech check for a low charge. This will cause the coil to freeze up. Humidifers are known to lose gas and owners aren't told this so end up buying new one and scraping the old one. Trust me on this. I have seen this many times. I repair high end machinery as my business.
Posted on Aug 14, 2009
Anonymous
SOURCE: E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Posted on Dec 31, 2009
Tip
Ice maker not working
This problem where the icemaker is not working properly is usually broken into sections on diagnoseing the issue of why your not getting ice out of the icemaker. One of the first things that you should check is if the icemaker is getting water to the ice tray. If you are not getting water to the ice tray then the first thing you should check would be your water filter. If your water filter is clogged or dirty you will not get any water going to the icemaker. Following checking the filter and if you still had no water going to the icemaker you would then go around the back of the machine and test the water valve. By using a multimeter you can test the two connectors that plug onto the solenoids to assure that you do have power going to the water valve. Also in some cases you may be able to disconnect the line and clean the small screens on the inside of the valve but most of the time if there is any issue with the valve it is by far easier to just replace the water valve itself. If you do have water going to the Ice maker yet your icemaker is still not working. You can also try defrosting the ice maker by disconnecting the three screws holding the ice maker in place and removeing the entire icemaker and running it under hot water. Sometimes this does help to defrost parts that are froozen in the unit. If after you reinstall the ice maker and you do have water going to the ice maker yet your unit still does not produce ice, and you can feel ice on the inside the tray and you have tried defrosting the ice maker. It is always easier and cheaper to replace the ice maker as a whole rather then buying parts for the ice maker which would cost you about Four times as much as buying a new icemaker
on May 20, 2011 | Refrigerators
Hoshizaki kml-250mah Ice Machine Problem. I had someone clean the ice machine and every time it leads to a service call I just can't afford. I get two a beep error. Now I replaced the filter, here's...
I see 2 issues for one ur water inlet valve may have gone bad the coils defective u can test it with a multi meter or any appliance parts store should be able to test it for you, also should do a live volt test on it as well. check for full 120, next thing that thing u said that measures temperature? Its called a thermistor and there should be atleast 1 or 2 in ur freezer and maybe 2 or 3 in ur fridge. and it should not be jumpered other words u will get variable termperatures. it should be tested with ameter and should show about In most models around 1300 ohms ( give or take 150 ohms)
Mar 29, 2015 | Hoshizaki Refrigerators
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Replaced ice maker in kenmore elite last year. stopped working again.replaced ice control sensor boards,still nothing.replaced module,poured some water in tray,freezes,rake starts down,hits ice then does...
the rakes can only move the ice if the tray has been heated .. there is a heater mounted on the tray that may be bad or not getting power . here is the sequence that should happen
the water solonoid operates to fill the tray (you should hear it click when this happens) .. then the tray is left alone until the cubes have frozen .. then the heater comes on to free the cubes from their mold then the rake operates to scoop out the ice .. the rake cant move the cubes unless they have first been freed by the heater .. it sounds like you have power (rakes moved) but its not clear if the water fill function is working .. even if it wasnt, if you filled the trays then it should still work but you would have to wait for the complete sequence .. you can feel the heater get hot at the right time if its working (just before the rakes move) .. its a bent tube structure mounted on the ice forming pickets .. be careful it can get pretty hot .. i cant tell but if several things are not working like it doesnt fill with water and the heater doesnt come on ever then that sounds like a connector not fully connected or damaged .. or perhaps a bad (new) module (broken solder connection or otherwise damaged) .. .. you can check the heater with an ohmmeter . it should read low resistance between hot terminals .. and open from ground to either terminal ..(power off and disconnected of course) .. make sure the heater is indeed plugged in ..
Oct 16, 2009 | Refrigerators
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice won't continue to drop from the dispenser
Check that the arm that is supposed to push the cubes out of the tray is working. If the tray heater is open and not working the ice cannot be removed from the tray because it is stuck - element has to be replaced. But given the high cost of parts it may be cheaper to just go out and get a new icemaker on ebay for relatively little
Aug 27, 2017 | True 598-TR1FRI1S Freezer Roll in One...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
