Cars & Trucks Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The car wont stay running when in the run possion
1986 ford tempo the car wont stay running when in the run possion but when i put in a new possion switch it ran for 5 mins now it wont wont stay running in the run possion
  • Ned C Cook
    Ned C Cook May 11, 2010
    I will assume you mean position switch, and what is a position switch?
Sean Wright
Level 3:
  • Ford Master 2,045 Answers
  • Posted on Sep 16, 2009
Sean Wright
Ford Master
Level 3:
Answers
2045
Questions
Helped
626586
Points
6368
OK lets start with this..
I am guessing that when you say possion you are meaning you gear selector and when you put it in say drive.
If that is the case.....
Your problem is most likely the fuel pump relay or fuel pump itself.
Start with checking, or have it checked, the fuel pressure at the fuel rail.
If the pressure is low then a fuel pump can be suspect. There are then other test which have to be performed to see where the exact problem is.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Gas release in ford tempo 1986
There isn't one. You have to pull the fuel pump fuse or relay. Start the car and let it run out of gas to relieve the pressure. All I do is loosen the nut at the fuel rail or fuel filter with a cloth/rag around it to keep it from spraying on me.
Wont shift out of first gear , put 2 quarts of fluid in and still wont change out of first. 1986 ford tempo
You fill it until the fluid leve is in the cross hatch imprint on the transmission dipstick. Make sure the fluid has reached at least 175 F before you make the final level check.
My 1984 F-250 wont start
possible float sticking in carb or fuel pump not working. can you see gas spray in carb when manually operating throttle? Does it backfire when running? if so it may have jumped time,
1989 ford tempo runs only when the ignition switch is in the start possionbut dies when in the run possion HELP
it sounds like your igntion lock cylinder is broken.
this is what hold the ignition in the lock, accessory, and run positions.
1helpful
Timing won't stay set on 1994 ford tempo. Put on a new distributor. Tried setting timing and it won't stay.
what do you mean it wont stay? Once you bolt it down, the timing cant move.
Mu 1991ford tempo fan wont turn off when i turn
does anything else stay on it sounds like you have a bad ignition switch
1helpful
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
