Question about Belling Ovens
Where could I get the dimensions for a Belling BCF 60
Posted by Jackie Kavanagh on
Belling oven wont heat on any setting
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven is Not Heating Up You can test whether your Belling oven is heating up correctly by turning the oven on, setting the temperature and letting it sit for five minutes. If the oven cavity is not hot when you open the door, it is likely that your oven element is broken.
Belling Oven Not Working? Here's How To Fix it
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at
http://www.elementreplacement.co.uk/belling-elecr11budget-332-p.asp
Check dimensions with the one shown
6helpful
3answers
Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
2helpful
Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
good for 60 days only
Ovens Logo
Top Belling Ovens Experts
Harrie
RudeRude
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
