SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
SOURCE: Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
SOURCE: After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Hi john Bramwell, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
make and model number ?
