Question about Watches
Kaiser clock model kc-2. it makes sound at night time, before it was not making sound at Night, after liquid from battery got out from that time it makes sound at Night also, please help me
Posted by Nesan A on
5 Related Answers
Anonymous
  • 150 Answers
SOURCE: Sony Dream Machine clock radio
0) Read the last answer first :) it is the most likely.
1) Make sure that the noise is electronic, not mechanical,
a) Electronic noise comes from the speaker
b) Mechanical nose originates in the clock
(older mechanical clocks only)
c) Clocks come in 3 varieties:
Electronic
Mechanical "Flip Leaf"
Mechanical "Motor/ Gear" driven.
2) Assuming that your clock is electronic, there are
only two possibilities for causing static.
a) Extremely intense electromagnetic interference,
as in radio waves, from a thunderstorm or a powerful
transmitter nearby, such as a HAM radio or even
an active cell phone.
Intense electro-magnetic waves can be picked up by
internal wires within the radio which act as an antenna,
rectified (demodulated) by internal diodes and transistors,
filtered by internal capacitors and the speaker's inertia,
and still present enough audio frequency energy to the
sensitive speaker coil to be "quite" audible and irritating.
This can happen even with the power off, when the
interference is so strong that it needs no amplification !
This happens to my computer speakers, every time my
cell phone rings, and starts transmitting a return signal.
3) The power switch is intermittently shorting causing a small
amount of DC power to enter the radio, the more intermittent
the switch, the more noisy it gets.
This causes my old clock radio to turn on by itself when its
not supposed to.
The cause of the problem in either in the main power/ mode
switch, or in the clock driven switch or relay.
4) Old switches and volume controls get oxidized with time
and/or bridged by products of corrosion. The simple solution
is to clean them using a good aerosol contact cleaner,
available from an electronic shop for about 10 bucks.
Simply spray the cleaner into all the switches and controls,
while vigorously exercising each switch or control back and forth.
Make sure that you use a safe "electronic cleaner" designed
for the job. It must be safe on plastics, non-conductive, good
solvent and it must evaporate quickly. Don't breath the stuff !!!
Typically the spray will contain TF (tri-fluoro-ethane), or some
other freon substitute.
Freon (Di-fluoro-di-chloro methane) is bad for the ionosphere,
now illegal in most countries for that reason.
Also stay away from Carbon-Tetra-Chloride, which is
VERY toxic.
Do NOT improvise, or use acetone or alcohols, which may (will)
melt the plastic, causing the controls to permanently seize.
Get electronic contact cleaner from an electronics hobby shop.
Good luck. Martin
Please rate my answers.
Posted on Jul 12, 2008
phoenixinks
Jason Robertson
  • 89 Answers
SOURCE: Woods Freezer Makes Loud Vibrating Noise at 10pm each night
sounds like either your compressor is loose and just rattling or the compressor is off balance and its rolling around inside the seal can.  take a look at it when it is making the noise.   put your hand on the compressor (careful   might be hot)   if it feel like it running smoothly then i would call an electrician cause that kinda puts me out of ideas without being there...  sorry
Good luck
Jason
Posted on Jan 15, 2009
livewire874
Alf Hopkins
  • 618 Answers
SOURCE: freezer side of refrig makes a LOUD howling, high
Sounds like the evaporator fan (behind rear panel in freezer.
Posted on Nov 20, 2010
Joe Hogan
  • 10865 Answers
SOURCE: Outside temperature not working on
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Posted on Feb 18, 2011
kaiserclock
kaiser
SOURCE: Kaiser clock model kc-2.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Posted on Mar 09, 2011
I have a radio controlled clock I bought from Aldi I cannot get the time to set from the time signal can you help please
Depending on where in the world that you are, the time signal might bot be strong enough to reach you.
Dec 18, 2012 | Watches
How do you change the time on vintage Syroco wall clock?
I bought a Syroco 8 day wall clock wind up with key at an auction it winds but does not make ticking sound and does not work ANY IDEAS?
Jun 13, 2012 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
I just got a Bradford exchange hour of glory cuckoo clock from a friend, I need to know how to make the cuckoo work, I installed batteries, wondering if there is something else to do or is it broken.
I am not familiar with the product you have. However, if this is a genuine cuckoo clock, driven by weights, the weights must be "wound", weights pulled to the top of their travel. If this is electronic, I would be looking for a switch. There also may be a electronic eye that prevents the sound at night. Can the eye see the light?
If you just got it, and if my comments don't apply, I am sure a quick call to the Bradford Exchange will solve your trouble, whether it is a step you inadvertently over looked or if the device if fault. I am certain they will help you.
Thanks for your question @ FixYa.com
Feb 17, 2011 | Watches
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
kaiser clock
Aug 04, 2010 | Watches
I live 20 miles, south of Seattle, WA. Please give me hints, how I can receive Radio signal, for my E. Howard, E23GA, Atomic watch. I haven't been getting daily signals. Thank you, Dave Harvey,
Place the watch near a window that faces Colorado. best reception is at night although you should get a signal during the day where you are. The signal comes from a transmitter in Colorado. Also, make sure your watch is a model with the US frequency as there are different frequencies used in other parts of the world. Read more at http://www.ntp-time-server.com/atomic-clock.htm.
May 23, 2010 | La Crosse Technology E. Howard Ambassador...
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Luminox 3100 series stops working at night
Sounds like there could be a bit of foreign material floating about inside, or the new battery was not up to scratch. Take it back for checking.
May 29, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
Watches Logo
150 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
