Question about Seiki Televison & Video
MY SEIKI TV 55 INCH SOFE WHERE NEED UP GRADE - Seiki Televison & Video
Posted by SEPTON on
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: 55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Posted on Dec 17, 2007
SD Tech
SD Tech
  • 14553 Answers
SOURCE: 42 inch led sieki tv comes on reads seiki then turns off what could it be
age does not matter very much----likely the set has a problem either in the power supply or even the main board that really controls all functions.
Posted on Aug 27, 2012
gopakumarg43
  • 76791 Answers
SOURCE: how do i fix an 55 inch seiki tv no sound or picture
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 24, 2015
Jay Edward
SOURCE: How much do you think it will coast to get a 55" seiki HD flat screen tv fixed
whats it doing?
Posted on Apr 02, 2016
gopakumarg43
  • 76791 Answers
SOURCE: I have a 55 inch Seiki tv and when I plug it in the standby light comes on for a couple seconds than goes off and that's it. Does that mean the power unit is bad or the main board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jun 11, 2017
My tv was on 1 minute and then the picture went out then the sound what could be a problem
Customer Reviews: Seiki 32" Class LCD 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/14978588
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
Customer Reviews: Seiki 32" Class LED 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/19717659
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
SEIKI TV SETUP - YouTube
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
25385173 My 32" seiki TV has no picture but sound
I cant turn of the audio voice that narrates over all the programs. I have tried on the audio page to no avail... Help please.
you need to look for "audio description" in your preference settings, and toggle it to off, here's the link for seiki user manual downloads, the info you need will be found in the user guide. http://www.seiki.com/support/download#manual
1helpful
I have a 55-inch Seiki TV purchased May 2012 For past 3 days stuck on dvd1 and no sound. How do I change to HDMI1?
Do a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
How do i fix an 55 inch seiki tv no sound or picture
My 55" seiki tv has sound but no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Televison & Video Logo
Top Seiki Televison & Video Experts
ADMIN Canada
ADMIN Canada
MrFixitSTTL
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
