Question about Car Audio & Video
Ok i bought a catadyne propane heater for my rv. I have a two wire thermostat red and blue wires, but i have three wires coming out of my heater, red, green & white the white being the ground. Which goes where and do i also have to connect tje heater to the 12v power as well? Yes i have all shut offs and switches in place already
2 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Connecting to ground or neutral
SOMETHING DOENST SOUND RIGHT ABOUT THAT AT ALL. i would contact an electrician, would not even want to venture a guess as to whats goin on . let alone advise to hook up a ground to a nuteral and cap the nuetral.theres somehtin up there . i would call in a pro on that one
Posted on Mar 11, 2008
SOURCE: Sainspeed 7" TFT-LCD monitor. The power lead has
If there is a letter on the electrical scheme right next to the wire it might be your answer ("BLK" would be black, "BL" or "BU" is blue, R, RD, RED stands for red wire). If the is no such thing on the schematic, it is best to not plug the wire by try and error. Red is not always the positive by the way, for instance, the red wire on my car radio is "hot at all time" because it is the voltage supply to keep the radio station memorized on it and the Yellow is the actual power supplier so the radio will turn on. Try calling the customer support in any doubt
Posted on Oct 20, 2013
2014 Heartland Fairfield 405fl (extendend stay) Suburban SF42-Q furnace Does anybody know of any Mobile RV Mechanics in San Jose Ca (Bay Area-South)? Our furnace blower fan went whacky and broke the cage....
Go to Bryantrv.com and click on the Service Manuals link. It sounds like he missed a wire hooking it back up. There are usually 3 wires, red for hot, connected to the furnace and also a small blue wire with a red stripe, another small blue wire connected to varying colors but comes from the thermostat and a ground, usually yellow. There is a relay on the fan side of the furnace and a thermal safety on the back side, under the burner. The fan gets it's power from this relay and the furnace will not run until the fan is turning. It's common for the relay to go bad but I've only had to replace on thermal fuse in the last 12 years.
Mar 16, 2015 | Heating & Cooling
I have a venstar t1700 thermostat which required a 24v transformer, hooked the two wire to R and C. Thermostats lights up and functioning. I have two wires running to propane heater a red wire and whi
R and C are the power terminals to the thermostat allowing it to run on 24 volts and not under battery power alone. Assuming that you used the R and C terminals from the propane heater to power the stat and NOT an external transformer, the W terminal on the thermostat then is connected to the W terminal on the propane heater. W energizes the heating control circuit when the thermostat calls for heat. The remaining portion of the control circuit should be prewired from the factory internal of the heater. If you do NOT have these terminals, more information is required for us to help you.
Nov 16, 2014 | Venstar T1700 Thermostat T1700
Cadet baseboard heater
If I have your information right you have a black wire and a white wire marked red coming to the heater with 240 volts between them. You have a double pole unit mounted thermostat with a red and a black wire. Most double pole thermostats have two red and two black wires on them so I am not sure if you have a double or a single pole thermostat.There are also two wires going to the baseboard heater. One is connected to the element the other to a high limit switch which is then connected to the other end of the element. If the thermostat is a double pole the two red (or load) wires should connect one to each of the baseboard wires. The two black (line) wires should connect one each to the two incoming power leads. If it is a single pole thermostat the one red wire should connect to one of the baseboard wires the black should connect to one of the incoming power wires the remaining baseboard and power wires should then be connected together. Hope this helps
Dec 12, 2013 | Heating & Cooling
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
I have a four wire system one is white red blue and green and i just bought the rth230b where do i put them at exactly
Red: Power (24 Vac) Green: Fan White: Heat Blue: Common
Now I would check those at the furnace BEFORE you hook the wires up.
Nov 21, 2009 | Honeywell Programmable Thermostat Heater
We have a duo therm rv analog thermostat. When we opened it up none of the 7 wires were attached. Do you know the wiring code?
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Oct 30, 2009 | Dometic Rooftop RV Air Conditioner
How to wire a Coleman proprane furnace
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Mar 07, 2009 | Coleman Propane Forced Air Heater...
Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Jan 26, 2009 | Honeywell Programmable Thermostat Heater
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
