Question about Optics
Year of manufactur for 2 remingtons #1 model 760 serial 178852 #2 fieldmaster serial 109362
Posted by cary blue on
5 Related Answers
trintek
Trinity Sabre
  • 111 Answers
SOURCE: TV remote
the remote for your durabrand combo unit is part number NE207UD and can be found online through many retailers, as far as i know there are no universal remotes that support the durabrand codes, if they do it will be under a different manufacturers name.
hope this helps,
trin
Posted on Nov 16, 2007
Blue Dog
Kevin O'Brien
  • 75 Answers
SOURCE: looking for the age of a Remmington model 121
These rifles were made between 1936 and 1954. There is more detailed information about them on the Remington website.
Posted on Oct 17, 2009
bigcass
Josh
  • 35 Answers
Cant give you an Exact but I can give you the Manufacture Years:
Manufactured from 1936-1954
Posted on Oct 18, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
Posted on Mar 03, 2010
jason zeringue
  • 141 Answers
SOURCE: what year was this product manufactured? Model
2003
Posted on Apr 08, 2010
Model 870 # s57499v,,,how old is it,,,I bought in Brockport. NY in approx. 1973
Write to Remington and tell them you want to know when it was made or left the factory. Start by mailing or calling them here:
Remington Arms Company, LLC 870 Remington Drive P.O. Box 700 Madison, NC 27025-0700 TEL: 1-800-243-9700 Fax: 1-336-548-7801
Feb 02, 2018 | Remington Model 870 Express Pump Shotgun...
I own a Remington 742 rifle , serial " 229608 . I want to know the facts or history of this gun .
Ricky, here is a link to the history of the Remington 742:
http://www.remingtonsociety.com/rsa/journals/Model_74N
This paragraph has the most pertinent information:
"The Model 742 serial number sequence was changed on November 26, 1968 as a result of the 1968 Gun Control Act that required no two guns from the same manufacturer have the same serial number. The initial Model 742 serial number sequence began at 1001 and ended at 396562. The new serial number sequence, now shared with the Model 760 pump-action rifle, began at 6900000"
Dec 26, 2014 | Optics
What year of mfg.108125 ?
Do you know what model it is?
Beings it's a .22, I'm thinking it's a Model 4, but usually those were a 22 1/2" barrel length.
1890-1933
Total production - approximately 356,000
If it's a "take-down" model, it COULD be a Model 6.
1901 - 1933
Numbers 00001 - 498,000
As far as serial numbers, a lot of them had the serial number on the side of the top tang, visible only with the action out of the stock.
Not all Remington serial numbers were consectutive for the model.
Military models were often numbered by the contract and commercial guns marked with batch numbers having little relationship to the time of manufacture.
May 11, 2014 | Sports Collectibles Remington Rolling...
Have a 572 remington fieldmaster serial number a1746190 trying to find yr made
Look at the date code on the left rear portion of the barrel. The codes are posted on line.
Feb 25, 2014 | Remington 572 BDL Deluxe 22LR Pump Rifle,...
I have a remington 22 cal model 12 serial number 187554 and would like to know the manufacture date
Introduction Year:1909
Year Discontinued:1936
Remingtons manufactured between 1921 and 1972 have a code located on the left side of the barrel near the frame that identifies the year and month of manufacture.
If yours is between 1921 and 1936, it should have two letters, one for month, and one for year.
If it doesn't have this code, it was made between 1909 and 1920.
REMINGTON Customer Service (1-800-243-9700 & follow the prompts) will look up your serial number and verify the age of your firearm.
Just to give some scope, serial number 757132 was 1929, about 569578 after yours.
Feb 20, 2014 | Optics
What is the year of my remington model 760 serial number 312208
Remington does have a vague timeline with their serial numbers for the Model 760, you can find it at the URL at the end, and it sounds like it was made between 1951 and 1967. If you scroll down on their OVERVIEW: on this page, it has a complete list of serial numbers and production years. Hope this helps.
http://www.remington.com/products/archived/centerfire/pump-action/model-760-gamemaster.aspx
Mar 28, 2012 | Optics
Have a remington model 12 serial number #127375 would like to know approx- year of manufacture
Remington Year of Manufacture Codes maybe found on the barrel of your Remington rifle [or shotgun] on the left side, just forward of the receiver; the first letter of the Code is the month of manufacture, followed by one or two letters which are the year of manufacture. For shotguns with removeable barrels, the code will be valid for the manufacture of the barrel; maybe for the receiver, as barrels do get switched around.
According to the "Blue Book of Gun Values", the coding continues as follows:
Month Codes: [first letter]
B - L - A - C - K - P - O - W - D - E - R - X
1 - 2 - 3 - 4 - 5 - 6 - 7 - 8 - 9 - 10 - 11 - 12
Year:______Code: [second (and third*) letters]
1930_______ Y
1931_______ Z
1932_______ A
1933_______ B
1934_______ C
1935_______ D
1936_______ E
1937_______ F
1938_______ G
1939_______ H
1940_______ J
1941_______ K
1942_______ L
1943_______ MMZ
1944_______ NN
1945_______ PP
1946_______ RR
1947_______ SS
1948_______ TT
1949_______ UU
1950_______ WW
1951_______ XX
1952_______ YY
1953_______ ZZ
1954_______ A
1955_______ B
1956_______ C
1957_______ D
1958_______ E
1959_______ F
1960_______ G
1961_______ H
1962_______ J
1963_______ K
1964_______ L
1965_______ M
1966_______ N
1967_______ P
1968_______ R
1969_______ S
1970_______ T
1971_______ U
1972_______ W
1973_______ X
1974_______ Y
1975_______ Z
1976_______ I
1977_______ O
1978_______ Q
1979_______ V
1980_______ A
1981_______ B
1982_______ C
1983_______ D
1984_______ E
1985_______ F
1986_______ G
1987_______ H
1988_______ I
1989_______ J
1990_______ K
1991_______ L
1992_______ M
1993_______ N
1994_______ O
1995_______ P
1996_______ Q
1997_______ R
1998_______ S
1999_______ T
2000_______ U
2001_______ W
2002_______ X
* the years 1943 though 1953 had double letters: ie, MM = 1943
As maybe seen, the year code letters duplicate; some knowledge of when the model was introduced should resolve the actual year of manufacture.
Remington owners: COPY this table to your Hard Drive......! !
another couple helpfull links: http://www.remington.com/library/his...irearm_models/
http://www.hsph.harvard.edu/nviss/do...Codelist21.pdf
Sep 23, 2010 | Remington Sport & Outdoor - Others
Looking for the age of a Remmington model 121
Oct 17, 2009 | Sport & Outdoor - Others
Oct 17, 2009 | Remington Electric Chain Saw
Optics Logo
146 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
