Question about Home
Where can i get instructions for setting sunbeam westminister quartz clock model 882-495 with precision measurement 31125
Posted by Esther Collier on
5 Related Answers
THOMAS DRESSLER
  • 11 Answers
SOURCE: 3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_6b90afb985d8f4bd
Posted on Nov 07, 2008
Anonymous
SOURCE: Seiko Westminster Chime Clock; Model No. QF0020 (or QF002G)
There is a small potentiometer that the volume know is on, probably replacing the pot will fix the problem. Radio Shack has these.
Posted on Jan 20, 2009
JohnB
  • 25 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
OldPoop55
SOURCE: instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Posted on Jun 08, 2011
Tom V
SOURCE: don't know how to set
It's very easy to do. First, make sure the 2 little slider switches on the far right hand side that turn the alarms on and off, are in the "down" off position.
On that clock, just to the right of the large snooze button there are 5 small square buttons. Time, Fast, Slow, Alarm set 1, Alarm set 2.
Depending on which alarm you want to set, hold down that button and simultaneously push either the "fast" or "slow" button to the left of it. The numbers will move forward fast or slow depending on which button you're pressing. Keep an eye on the upper left corner to determine when you've gone past 12 noon - as the indicator for PM will light up.
Keep holding down the 2 buttons until you get to the time you want. Then immediately release the fast/slow button. Your time is set. Do the same for alarm 2 if needed. When finished, flip up the switch for the alarm you want to activate, and you're good to go. Piece of cake! It took me a few minutes to figure it out; but after doing it one time...it's easy. Hope that helps.
I love this old Sunbeam clock. Only problem is the alarm is not very loud and there's no way to raise the volume - short of connecting wires to the speaker and using a powered speaker. Cheers!
Posted on Oct 30, 2011
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register · My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How do I set the date in my sterling and noble LCD Quartz alarm clock
Apart of your nice qualifications to your sterling and noble LCD Quartz, need it's make and model to get, if possible, user's manual so you might find out how to set date.
Please reformulate your question
May 07, 2015 | Audio Players & Recorders
How do I start my clock after changing the batteries?
Once I make sure the battery is in correctly, I just lightly smack the clock on the right side wit face towards me and the thing starts moving. Works for me.
Nov 15, 2014 | Home
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do i set the clock
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://dl.owneriq.net/1/15998b55-9a96-49c5-8bf1-7614a81ed4b1.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 8 of the manual for instructions on how to set the clock on this model.
However, only some models will allow you to change between standard and military time display modes. Try holding down the CLOCK button until the display prompts you to enter the time. Then tap the CLOCK button once more to see if it will let you switch from military to standard time. See the following link for additional details about Sunbeam microwave clock instructions:
http://www.ehow.com/how_8197135_change-clock-sunbeam-microwave.html
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 22, 2011 | Sunbeam SMW777 Microwave Oven
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 | Watches
I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Jun 23, 2010 | Watches
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
Home Logo
122 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
