Pitney Bowes 1530 Memory Full
Pitney Bowes 1530 fax machine displays "memory full" and stopped faxing. How do I clear the memory? Turning it off/on didn't solve the problem.
Posted by annamckinney on
Nike Merritt
  • 149 Answers
1. Press FEATURE
2. Press 9 9
3. Press * * * 1 (this is the service passcode)
4. PressYES
press 095
press yes
press stop to exit
Posted on Dec 21, 2009
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Memory is full
Unplug the power cord for 30 seconds.
Oct 23, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Jan 31, 2009 | Pitney Bowes Office Equipment & Supplies
How do i clear the memory full?
Turn off the machine, wait a few minutes, and turn it back on. The memory is now erased.
Dec 04, 2008 | Pitney Bowes 9920 Plain Paper Fax
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Pitney bowes 1530 / INCOMING fax date/time stamp
For the UF-595 here's how you turn the fax stamp on:
Function + 7 + copy/set for enter
scroll to option 4 + copy/set
Hit 04 + copy/set and enter number 2 to turn the fax stamp on. 1 turns it off.
Scroll to or enter 28 and choose 2 to turn the fax stamp on for faxes stored in memory for later use.
You hit the "clear" button to wipe out the current number before you enter 2 or 1 for the new entry.
Jan 08, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
524 people viewed this question
Marvin
Marvin
