Pop banner keeps showing up every 30 seconds to a minute on the left side of the screen on my new 40" Hisnse tv
    Habit-Forming:
    New Friend:
  • 89 Answers
Go into 'menu' then 'controls' then 'allow ads' turn to 'off'
You may have to search awhile, they tend to bury it deep into the menus on some of those models. Also should be a 'allow popups' setting that needs to be turned to 'off' too, as some providers piggyback "popups" with their programming, stinks I know.
Posted on Oct 06, 2019
5 Suggested Answers
Anonymous
  • 337 Answers
SOURCE: Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Posted on Sep 07, 2006
Anonymous
  • 44 Answers
SOURCE: 42 LG Plasma
It can be fixed but about $300 in parts.
Posted on Jul 03, 2008
Anonymous
SOURCE: Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Posted on Sep 18, 2008
Chi Chu
  • 8457 Answers
SOURCE: polaroid tv screen goes black after 30 40 minutes,
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Posted on Jul 05, 2010
Chi Chu
  • 8457 Answers
SOURCE: Every day when I first turn on my LG HDTV model
The board that call the T-CON decoder board is dying this board job are decodering signal before it go to LCD screen panel.This T-CON decodering board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Posted on Mar 02, 2011
How do I get rid of banner across tv
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Video Disappears Intermittantly
The TV power supply may be failing.
Oct 19, 2017 | Vizio VP322 32 in. Plasma TV
My Sony LCD HDTV, 60", about 6 years old, times out after about 35 - 40 seconds and I lose video and audio while the power light blinds. After about 35 - 40 seconds I get video back and a few seconds...
Try this...... Remove the front panel to access the bulb. There are 2 screws on either side of the tv right behind the screen. You may be able to remove them with just your hands. It will make sense when you see them. Once they are loose the panel will pop off. There are 2 magnets that help hold it on, so just pull gently. In the middle you'll see a another scew that you need to loosen. Slide the bar off, remove the cover and you'll see the black box that holds your bulb. There is an allen screw on the left side that will need to be loosened. Once that is loose, the whole unit slides out. Is the top of the vent screen really dirty? If it is, flip it over and try dusting it off with a soft brush, maybe a tooth brush. Try to keep most of the dust out of the bulb itself though, just be gentle. Pop it back in with the reverse order.......
Jan 23, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
42 inch lg tv powers on,goes off after about 30 seconds
hello my friend you have some loose connections on the digital board.this board is located right in the top center of the tv.if you do not have repair skills call the repairman he should not charge you too much for this job. good luck
May 31, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Upconvert Problem
Turn the power off. On the front of the tv hold down menu then power then channel down, in about 8 seconds the service menu will come up, go to geometry and write down the original settings before you begin. Adjust, check store and hit menu to exit. Problem solved........NEXT!
Nov 09, 2007 | RCA Scenium D40W20 40" Rear Projection...
Tv problem
there is a triangle that shows up on the side of the tv screen
this type of problem is due to vertical yoke winding wire is loose or its connector seems to be loose.or part connecting to winding is loose or orint loose.
as you say that it goes away after 30 to 40 seconds.so no possibility of components failure.
if you are not tech person tech the help of tech person.
hope this will help.
Oct 11, 2007 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
