Question about Casio Office Equipment & Supplies
My CASIO printing calculator is not working well. It seems to be an error. Please help me!
The total number on the screen is different from the total amount printing out
Posted by So Mi on
5 Related Answers
Misty Hoffman
  • 374 Answers
SOURCE: printing problem
Try resetting the calculator. There should be a reset button on the underside of the machine. Press it with a pen and that should clear the E that is on your display.
Posted on Jul 10, 2007
Anonymous
SOURCE: how do I change the
How do I program tax rate into my calculator? Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Dec 10, 2008
Anonymous
SOURCE: Casio FX-880P and TM Error
You need to reset you calculator. With the casio fx 880P on, press "P" in the back until the display goes off, then press all reset, next to the Power On. If it doesn't work, try again.
It worked with me. Daniel.
Posted on Apr 07, 2009
Anonymous
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Posted on Jun 29, 2009
Anonymous
  • 81 Answers
SOURCE: how to calculate logarithm values with different base
Like you maybe know in math (I know!) log x base y = log x / log y
so what you need its just input your number (x for example) and log it, than divide log x by log 2.
just: log x / log 2. (by the way in calculator the meaning of log x is log x base 10 the default base is 10)
Posted on Jul 06, 2009
We hit a button on Casio HR-170RC and now it keeps rounding up. How do we stop this?
It is the slide switch for decimal places. You needs to be set to 2 places.
Slide Switch ' Printing Calculators ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > Printing Calculators
Q1: What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for? (HR-8 series); A1: The HR-8 series have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4]. The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F ... Missing: 170rc
HR-170RC ' Calculators ' Manuals ' CASIO
support.casio.com > Support > Manuals > Calculators ·This page might be unreadable or wrongly displayed depending on your browser, OS version, and settings. In this case, please try with different browser (Chrome, Firefox, etc.) ·We recommend you to download the large PDF files from this site and view them off-line. [ To download a file ] 1.Align your mouse pointer with the ... Missing: rounding
[PDF]HR-170RC HR-200RC - Support - Casio
support.casio.com/en/manual/004/HR-170RC_200RC_WA_EN.pdf - Translate this page
Mar 15, 2017 - Back-up Battery. Your calculator comes with a single built-in CR2032 lithium battery that provides power to retain values stored in memory when you leave the calculator without power (AC ... Weight: HR-170RC: 570 g (20.1 oz) including batteries ..... performed with values as input, and the result is rounded.
Slide Switch ' General Calculator ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > General Calculator Q1: What is the use of the Slide Switch? A1: F: Floating Decimal CUT: Values are cut off to the number of decimal places specified by the current Decimal Place Selector setting. UP: Values are rounded up to the number of decimal places specified by the current Decimal Place Selector setting 5/4: Values are rounded off (0,1 ...Missing: 170rc
Mar 01, 2018 | Casio Office Equipment & Supplies
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
Jan 21, 2016 | Casio Office Equipment & Supplies
How do I get a casio hr100tm to print the total?
Once you enter your number like so (5.00 press (+) 11.00 (+) 5.00 (-) then press the *key, should be bottom key next to + = key). Hope this helps, sorry to be so late with an answer.............
Jul 22, 2014 | Casio HR 100TM Portable Printing...
Hello, i have a casio te 2000 and i need it to divide the grand total into 4 because i have 4 employees who are using it. However as they use the register at different times they dont need different clerk...
Sorry, clerk system is totally designed to do this. Have them sign on as a different clerk number and print a clerk report before your daily one
Jun 22, 2013 | Computers & Internet
Casio calculator fx115es inverse key not working consistently
The inverse sine is defined only for numbers in the range [-1, +1].
The sine of a number is at most 1.0. There is no number whose sine is 1.5, which is what you're asking for.
The same applies to the cosine and inverse cosine.
Oct 24, 2011 | Casio FX-115ES Scientific Calculator
Estimate the total cost by rounding the total cost of each car an
195 reps --> 200; $21710 --> $21700; 200 * 21700 = $4,340,000
Sep 04, 2009 | Casio MS-80TE Calculator
Pritning TOTALS
Use the * key.
If this helps, Please rate me. Thanks, Patty
Dec 22, 2007 | Canon P23-DH Calculator
Casio HR-100TE
The problem of your unit is its printer. Probably the gears has misaligned. Only an authorized technician can align the printer of that unit, because it is a bit difficult to align the gears.
Try to contact the nearest service center of casio in your area.
Oct 13, 2007 | Casio HR-100TEPlus Calculator
Item Count
The item counter isn't available on this model.
Apr 20, 2007 | Casio DR-250HD Calculator
Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Mar 13, 2007 | Casio MS-80TV Scientific Calculator
103 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
