Question about Reddy Heating & Cooling
We have a Reddy heater 18,000 btu invented infrared propane heater mounted on our wall. How far away must everything be in order for it to be safe? First winter in this apartment and haven't started it yet but would like to!?
Posted by Traci Buckley on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Posted on Mar 02, 2008
Anonymous
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
Anonymous
  • 188 Answers
SOURCE: REDDY HEATER 40,000 BTU KEROSENE&DIESEL
Clean your nozzel, check your fuel & air lines, you may need to replace Spark plug and filters. You can go to the manufacturers website at www.desatech.com and they offer service manuals. I hope this helps you!
Posted on Jan 28, 2010
Anonymous
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: i have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Sep 21, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Need thermocouple for bantam rinnai reh 18tp
Its an ODS thermocouple. Should be fairly available. Try your local hardware store or better yet- look up a local propane company in your phone book. They'll have one. theya re the same on all the newer gas heaters.
Jan 27, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
83 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
