Question about The Video Game Consoles & Games
What would cause the whole system to slow to almost a standstill on an original xbox
Posted by Dan Blake on
I have an original Xbox 360 console and an original Xbox 360 Wireless Networking Adapter. I cannot connect to the Internet, but when I plug the adapter into the Xbox 360, the light turns red for a...
you can not fix it yourself, or you'll void xbox 360 warranty policy. If your xbox is flashing red, you have set off the red-ring-of-death, also known as (rrod) the ring itself is telling you your xbox has been damaged and needs to be fixed (not by you tho, but by the xbox company).This can be mostly caused by poor airflow thru the system and overheating from the cause of it. For future reference, try to research about keeping your xbox from having this happen. One thing you will less likely find in this search for help , is that you should avoid having your xbox 360 standing up. I know you can have it standing up the long way, because it looks more awsome this way, but the thing about that is, your giving the console less air ventilation from flowing thru the xbox that is needed. put the xbox on its flat side with all air vents showing and not blocked. This will cause less of a chance from getting (rrod) again.
Jul 30, 2013 | Video Game Consoles & Games
My janome sewist 509 is running really slow almost at standstill what can be causing this
could be the power cord not being plugges into the machine
enough or the power cord is going out
or it could be the foot pedal is going out
it would be a good idea to have the machine checked
Jun 27, 2012 | Janome Sewist 500 Sewing Machine
Status code 351f0000d08002008007045d my xbox started running extremly slow online
Your Hard Drive/Memory Card is failing, You must replace your hard drive. the reason why its running slow is because your hard drive is not sending its info fast enough which causes to slow your system down.
in order to clear that update code you must disconnect every memory unite you currently have, get a USB drive and got to xbox.com/support and download the latest update files. Insert your USB and your system should accept the update.
Thanks
www.1RepairStop.com
Sep 15, 2011 | Video Game Consoles & Games
Original Xbox wont read discs, need help!
only original xbox games that work on 360 r the ones that u download on the xbox marketplace. i heard that there r no plans to update the console so that all originals work. cause they only released the best selling xbox games on the marketplace and prob wont release any more so i heard. its a sahme to cause i loved that mad dash racing and wish i could play on me 360 or that they would make it an xbox original
Oct 05, 2009 | Video Game Consoles & Games
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
Xbox slow loading and then freezes
sounds like the the processor is over heating and its causing the system to shut down before it burned up the board. basicly your thermal paste between your processor and the heatsink isnt doing its job. there could be a crack on it might have just degraded over time.
this can cause the system to freeze or see things ont he screen. it needs to be repaired before more issues happen.
[email protected] for help
May 04, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
129 people viewed this question
Top The Video Game Consoles & Games Experts
Jun Salazar
Level 1 Expert
Marvin
Marvin
Lawrence Oravetz
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
