Question about Pan Photography
How do i get pictures of my Pandigital PAN 7000DW photo frame?
  • Pan Master
  • 6,227 Answers
Probably the easiest way is to take the photos yourself, either with a digital camera or your phone. There may be some images of the equipment to be found via Google.
Posted on Oct 05, 2019
5 Suggested Answers
Anonymous
SOURCE: I NEED A INSTRUCTION MANAL
I got my digital "pandigital frame last year and lost the instructions. Can you tell me how to download photos from my PC via Usb to frame?
thanks Deejohn2127
Posted on Dec 07, 2008
Anonymous
  • 6 Answers
SOURCE: Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Posted on Dec 11, 2008
Anonymous
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
robmcd27
Rob
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
Anonymous
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Posted on Dec 28, 2009
Instruction_Manuals_For 7 inch cibox photo frome
If you mean the PanDigital DPF701, Retrevo has a link to the manual here: http://www.retrevo.com/support/Pandigital-DPF701-Digital-Photo-Frames-manual/id/7008ag810/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 20, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
Where can i get a ownermanual for my pandigital 8 inch digital photo fram
visit www.driverguide.com , sing in , search, download and install all driver that you want, just put in searcher your model and searchit
Aug 06, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
My pandigital photo frame is frozen on the sytem start screen
Mine does this when the power cord shorts itself out. For a whileI could fix it by simply untwisting the cord close to the plug, but eventually I had to cut and splice the cord to keep the lines separate (think a bunch of electrical tape. It works fine now that the cord isn't shorting out. Hope this helps!
Feb 02, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Built in memory full...?
I have new camera ,After shooting 12 photos it's show Built in memoru full and cannot shoot anymore
Jan 23, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Will my photo frame read SDHC cards
You don't mention the make and model of your frame. You need to check your manual or just punch up your frame model on the net and check. Many frames DO NOT read a card above 2gb so you are wise to check before you buy one.
Dec 30, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
The Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
Dec 26, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Nov 23, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
thanks Deejohn2127
Oct 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Photography Logo
77 people viewed this question
Top Pan Photography Experts
Ekse
Marvin
Marvin
Are you a Pan Photography Expert? Answer questions, earn points and help others
