Question about The Kitchen Appliances - Others
SOURCE: Rival 3-L Cool Touch Deep Fryer
It sounds to me like it could be one of two things.
Either the magnetic cord safety thingy came slightly undone (which happens to mine constantly) or you didn't turn the timer to "always on".
The thermostat itself does not turn the heating element on, you must turn the timer to always on to preheat the oil, then when it's heated you can set what time you want to fry for.
Posted on Nov 18, 2007
SOURCE: Gaggenu VF 112-610 Deep Fryer
www.gaggenau.com has a service link. The site is not really user friendly so enter the model number as VF 112610 and select the parts list. The heating element is listed at 158.00.
Posted on Jun 17, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
SOURCE: missing the eye piece for the Meade saturn 60az-m
ebay is a great resource for eyepieces, i would suggest a 26mm ma.
the eyepiece should drop in. if not you might be missing the image erecting diagonal. when the eyepiece is installed you should be looking perpendicular at the tube.
Posted on Dec 09, 2008
SOURCE: imperial cif 40 single tank bouble basket deep gas fryer
When the whole unit shuts down including the pilot light the thermocouple is not working properly. The thermocouple is what tells the gas safety valve that the pilot light is lighted. When the thermocouple fails and does not send the milli-volt (mv) signal to the gas safety valve due a failure the gas safety valve turns off the gas supply. (i.e total shut down)
If you have a handyman around you can have him disconnect the thermocouple from the gas valve control and clean the mating area in the gas valve and on the bitter end of the thermocouple. After cleaning then reconnect the thermocouple. This sometimes corrects the problem. FYI you can get a thermocouple at most any large appliance parts supply. (You will need to the know total length) It would be even better to have the old one in hand during the trip to the parts store.
Thanks for using FixYa,
Kelly
Posted on Apr 25, 2010
Dec 14, 2015 | Kitchen Appliances - Others
Nov 25, 2010 | Masterbuilt 20010306 Deep Fryer
Sep 23, 2010 | Rival CZF725 Deep Fryer
Aug 08, 2010 | Kitchen Appliances - Others
Feb 25, 2010 | Imperial IFS40 Deep Fryer
Sep 04, 2009 | Bravetti Kitchen Appliances - Others
Jul 04, 2009 | Bravetti Kitchen Appliances - Others
Jun 28, 2009 | Maximatic EDF-4080 Deep Fryer
Apr 01, 2008 | Bravetti EP4305FS Deep Fryer
Dec 30, 2007 | Gaggenau VF 230 Deep Fryer
117 people viewed this question
