The unit may have a paper jam or stuck object inside, if you
have experience a paper jam error before, check the printer for any
object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Hi
Thanks for using FixYa. Please
check for stuck bits of paper under the carriage. Also make sure there are no
paper jams near or around the feeder rollers. Make sure that the paper rollers
inside the rear access door rotate freely.
Please see this link for details--
HP Printer Stuck Carriage
Also check for paper jams inside the printer head, see this link for details--
HP Printer paper jam
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Hi
You can access the carriage by opening the cartridge door on the right(next to paper feed tray). The glass top will not open, its just an exploded view thats why its seems that glass top raises.
You can follow the procedure given in the previous link. If that doesn't help then try and reset your printer by Pressing and holding # and 3 while plugging in the power cord.
Thanks
Rylee
Hi
Please try to move the cartridge case manually while the
lid is open and place it in the centre position and then follow the procedure
once again to resolve the issue you are facing with. Also follow the steps to clean the
back rollers, front rollers, carriage rod, and pitch rollers as provided
earlier in first link. And also follow the steps to clean the
carriage contacts and the capping station.
Turn the unit off. Unplug the power cord from the unit. Wait 30 seconds, and then re-connect
the power cord to the unit. Turn the unit on.
By following all the above procedure, the
cartridge case will certainly move to its normal position and printer will
start printing normally.
Please do
assistance.
Thanks
Rylee
Hi
Please do
assistance.
Thanks
Rylee
Well it's likely two cause in your case -
1.- It might be a misplaced actuator, check for instructions at:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=58057&dl...
2.- Check the power supply and its cable. It might be at the end of its life. Ideally, you should check the power supply under load at its limit. You may use a resistor rated for the load. It will be HOT, be careful. If you don't have it, might be more cumbersome, but you can use the printer as load, and make a test connector that allow you access to voltage terminals.
Good Luck!!
Thanks
I know just enough about computers to be DANGEROUS! The cartridges are STUCK in the change cartridge postition on the right side -- and the door is open. The RESUME light is ON. When I push the RESUME button the cartridges TRY to travel to the left but are appafrently striking something with a loud clicking noise. It tries three times to return the cartridges -- with the CLICK sound and then the RESUME light comes back on. I tried removing the color cartgridge and it performs the same routine.
HP F4280 printer still has the cartridges LOCKED in the replace position
This whole adventure started with a paper JAM.. I have looked in the back and saw NO pieces of paper. Actually, I was using AVERY 8376 "Ink Jet Business Cards" and was approaching the final settings to put all ten carfds where they are supposed to be. When the printger stopped, most of the sheet was sticking out from the front so I jusf slowly pulled it back out of the printerf. Trying to restart the printer only produce three loud CLICKs as the cartrides were trying to return to the left and the resume light came on. I did NOT notice any message on the computer screen.
We may be on the RIGHT course B U T ; I get lost at Step #2 "OPEN Carriage access door"! From the picture it appears that the glass top raises somehow but my fumbling found no release to accomplish this. Can you HELP? OR -- does the glass NOT raise?
If that doesn't help then try and reset your printer by Pressing and holding # and 3 while plugging in the power cord. WHERE? The carriage seems to be "stuck" in the remove cartridge position on the right side of the printer. SOMETHING is blocking the travel of the cartridges. With the cartridges REMOVED, should it be possible to move the mechanism to the LEFT. It is HITTING something that is preventing it to move.
This issue is URGENT -- I have to print over 200 pay checks and NO PRINTER. Starting over! The problem was caused by a paper jam. The priner made strange noises and finally got silent. I removed the jammed sheet by pulling it back out the front very slowly. Came out in one piece with NO pieces remaining in the printe. The RESUME light was flasing on the printer. Pressisng the RESUME buton the printer made three loud clicking noise and returned to flashing RESUME. The cartridges are in the change position on he right of the priner and are hitting something that prfevents it to travel back to the printing position. Pushing the RESUME button just repeats the 3 clicks and the cartridges are still in the change posiion. Pay day is FRIDAY -- H E L P !!
LAST TRY! There is NO paper stuck in the printer. The carrtridges are positioned in the replace position at the RIGHT of the printer. The RESUME light is FLASHING. pushing the button produces three LOUD bangs -- the cartridges are hitting something that is preventing them from going back to the printing position. With the printer disonnected ffrom the power,the cartridges can not be pushed manually to the left. They are hitting something that is blocking them from leavng ghe change cartridge position.
