Question about Staples Office Equipment & Supplies
I want a lock key for a Staples Shredder Model SPL-TMC12A
Posted by Bub Parritt on
5 Related Answers
Anonymous
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
Anonymous
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
Anonymous
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
electrotech1
Veril Gillette
  • 1126 Answers
SOURCE: I have the Model SPL-QW120D
There is a door switch that might be defective and that is why it will not run, replace door switch.
Posted on Jan 02, 2011
Thomas Webb
SOURCE: Staples SPL -TXC15A Shredder on all the time
This is what worked for me.
1) unplug the shredder
2) put the selector in "auto" position. This pulls back the guard which blocks the paper and hids the sensor.
3) a little right of the center of the paper slot is the sensor. You can feel this by inserting a cotton swab in ths slot.
4) put some alcohol on the cotton swab and clean the sensor!!!!
Also the "bin full" sensors are under the shretter head. You can easily see those when you remove the head from the bin by flipping it over. I would advise cleaning those while you are at it. Mine were covered with dirt and dust.
Hope this helps!!
Tommy
Posted on Jan 31, 2013
Lockout key replacement for paper shredder model# SPL-TXC122A
I am not sure what you mean by a LOCK OUT KEY but perhaps this link to the manufactures site might help.
www.fellowes.com/us/en/support/Pages/faqs.aspx Fellowes Support FAQs
Jul 13, 2014 | Staples SPL826X (CrossCut) Shredder
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
66 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
