Question about Konica Minolta Office Equipment & Supplies
Konica Minolta (bizhub283): 1st tray is not detecting and try light is working without blink. all the other trays and the bypass tray work fine.
2nd tray is working properly. I have removed all the paper and tried to see if they system would recognize the empty tray it does not. anyone have any idea on how to do so?
  • Konica Minolta Master
  • 6,876 Answers
Does the first tray display on the control panel or does the machine state that 1st draw is unavailable? Go to service mode and reset the first draw electrically.
Posted on Feb 17, 2020
Anonymous
  • 145 Answers
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Posted on Mar 18, 2009
Konica Minolta BH164 Copier gets paper jam in LGL and FS size papers only what to do
then place the LGL and FS in tray one does it work??? is this printing or copying???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 11, 2016 | Konica Minolta Office Equipment & Supplies
Bypass tray has correct paper size but gives error message to add correct paper size. Won't print
Once you have the message, try removing the paper from the bypass tray, then introducing it again. Alternatively, leave the tray empty then send the data, when it asks for paper, introduce your 11 x 7, and it should work.
Mar 19, 2014 | Konica Minolta Di3510 Copier
Error CO202 Bizhub
C 0202 - 1 st tray lift up failured.
Remove the 1 st tray,in the right side located 1 screw and in copier is a paper when blocated the tray lift gear.Remove the misfed paper and push in the tray ,open and closed the right door and the copier must be ready.
C 0204 - 2nd tray
C 0206 - 3 rd tray
C 0208 - 4th tray
C 0211 - bypass tray
Good luck.
Feb 14, 2013 | Konica Minolta PRINTING - Bizhub-250...
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
Our Konica Minolta C351 won't pull from any tray but 1
you may have to under configure in your print driver go to acquire settings and that should update the driver so you can use all 4 trays
Mar 02, 2010 | Konica Minolta bizhub C250 All-In-One...
Misfeed detected. Correctly position the bypass tray. I have a BizhubC451 printer, and it makes a loud awful sound when I try to load paper into what I think is the bypass tray. HELP!
When you install paper in bypass tray you must touch the bypass button and tell it what size paper and type of paper you are using or it will jam everytime, let me know if this helps, e-mail me at [email protected]
Nov 18, 2009 | Konica Minolta Office Equipment & Supplies
hope that help
keep us posted
Mar 06, 2009 | Konica Minolta Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
