Question about Homelite Garden
How to replace cutting line on homelite model HLT4030
Posted by john barry Clark on
1 Related Answer
Anonymous
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
Homelite super ez auto. Replaced fuel line and filter. Sprayed carb clnr in carb. It will start but will not rev up to cutting speed.
Try adjusting the H needle valve 1/8 turn in see if better then if not go 1/8 turn other way.
Dec 28, 2016 | Homelite Garden
Homelite Pro weed trimmer, model TLT254EBC. Where can I find a replacement carb?
go to any mower shop that repairs homelite and get one
go on line to homelite select the page for replacement parts and order on line .
previous pages give a price between $12 -30$ us.
try e-bay for carby
May 20, 2015 | Homelite Garden
Need two parts for homelite gas trimmer model number st -145 i need the retainer and the string head and the post can i order on line or do you have a dealer in s.c. i live in spartanburg s. c. also...
You'll probably need to just purchase a replacement head for your trimmer. You can buy one from PartsBuggy.com here. You'll need part #385-580.
Please note: The replacement parts shown when you click the link for the item # are replacement parts for the head being sold and may not necessarily fit the original Homelite head that may be on your trimmer.
Aug 29, 2011 | Garden
My Homelite Mighty Lite has developed perished fuel lines. (12 months after purchase!!!!!!) Is it possible to obtain spare fuel line.... preferably attached to a new fuel tank as well. It looks like a...
The fuel lines can be purchased separately usually by the foot from any outdoor power equipment dealer. They can be easily installed by cutting one end at an angle and "feeding" it through holes. Homelite fuel lines are of a different OD than most so make sure you get the proper size. The most popular size for Homelite is OD .203 ID .04.
Feb 12, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a 25cc homelite weed trimmer.... the fuel line is loose in the fuel tank... how do i get it back in
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Sep 27, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
How do I replace the fuel filter and the two fuel hoses on my Homelite leaf blower? The fuel filter is inside the fuel tank.
Take your Model number of your machine and the model, type, and code of your motor to your local small engine repair shop and have them get you your replacement filter and also pick up new gas line. When you replace your fuel lines do one at a time. All you have to do is pull a fuel line off, cut new line to length and re install. As to the filter in the tank, I usually take a coat hanger and fish it up to the top and then use needle nose pliers to grip it. Then just pull off the old filter and install new one.
good luck
Aug 31, 2009 | Homelite 'Yard Broom' Leaf Blower
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Jun 10, 2009 | Homelite Garden
Garden Logo
95 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Nick Olsen
Are you a Homelite Garden Expert? Answer questions, earn points and help others
