Question about Magic Mill Food Mixers
Hi I have a magic mill mixer 9000. Plug it into socket (socket is working) won’t turn bowl. Sincerely Valerie
Posted by Valerie Lui on
4 Related Answers
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: magic mill mixer
majicmill.com
You may be having a problem with the motor brushes and/or bearings.
Posted on Mar 04, 2008
Anonymous
  • 4 Answers
SOURCE: instruction manual for magic mill 2000
http://magicmillusa.com/items.php?category=26
Posted on Sep 16, 2008
Dennis Boxerman
  • 1303 Answers
SOURCE: N50 Hobart mixer is not switching on
Very strong possibility that one of the safety switches has gone bad. I've found, on the last one I worked on, that the safety at the back of the bowl, where the guard hits, when in place, was bad. Drove me crazy trying to find it.
Good luck and hope this helps.
Posted on Apr 03, 2009
Slo Mover
  • 185 Answers
SOURCE: Grain mill stops turning
it is more than likely that there is a stripped drive gear inside the mixer, either the attachment hub gear or the pinion gear has stripped and you hear the gears grinding up the nylon parts of the gear. soon it will stop altogether because the wear will be so great that it will no longer engage at all. You need to open the mixer and replace the gears that are worn.
Posted on Sep 21, 2012
Get the bowl to release from the stand
The only way to unstick it is with more energy. Get someone to hold the motor unit firmly and someone else turn the bowl anti clockwise. There is no magic if it's stuck, just more effort required.
Feb 20, 2015 | KitchenAid K45SS Classic Stand Mixer
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
May 26, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
Where can I download manual for the Magic Mill DLX2000 ?
The manual is $10 from the manufacturer, you can order from the following link.
http://magicmillusa.com/index.php?event=product-detail&productid=51
Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Magic Mill DLX 2000 Stand Mixer
Can't move the lever to start the machine - it's frozen on off position.
Unplug first. Mixers can detach from the bowl base. You may have a lockout either in the latch mechanism or in the beaters. Try removing the mixer head from the base and the beaters from their sockets. Then plug in and try switch. If not working, unplug and attach beaters. Replug and try. Then attach to base and try again.
Make sure speed control does not have safety feature requiring to press in before turning control.
Good Luck.
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Instruction manual for magic mill 2000
Jun 24, 2008 | Magic Mill DLX 2000 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill mixer
majicmill.com
Mar 04, 2008 | Magic Mill DLX 2000 Stand Mixer
Magic mill DLX 2000 base sent to repair place
I just found my old invoice where I had sent my DLX to be repaired a few years ago. (I had not put in enough moisture and it walked off the (rickety) table I had set it on...)
I need to send it back again and hence my search for the info.
The gentleman I sent it to was Mordechai Roth at Magic Mill Corp in Monsey, NY (10952) This occurred back in 2000, I can't believe I saved the receipt...
Phone number is 914-368-2532 (If it's still good) I am calling tomorrow to see about sending mine in... Hope you find yours...
JT
Nov 06, 2007 | Magic Mill DLX 2000 Stand Mixer
Food Mixers Logo
122 people viewed this question
Top Magic Mill Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Magic Mill Food Mixer Expert? Answer questions, earn points and help others
