Question about Poulan Garden
Size of spark plug
Poulan Riding lawn mower 826 le
Posted by Frank Slauenwhite on
Daddios
    New Friend:
  • 37 Answers
You use a 5/8" or 13/16" spark plug socket for removal and installation. It takes a Champion RN9YC.Check socket on the new spark plug for size.
Posted on Oct 05, 2019
5 Related Answers
Lawrence Thornton
  • 11 Answers
SOURCE: Mower bades
I have a 2007 pollan pro 19 hp mower that i have changed the blades on and they were not reversed threads righty tighty lefty loosey
Posted on Sep 26, 2008
Anonymous
SOURCE: POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Posted on Aug 10, 2009
Anonymous
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
Anonymous
SOURCE: poulan riding lawn mower starts but won't shift into any gears
where do you tighten the cable for the cluch
Posted on May 20, 2010
dillons41
SOURCE: I have a 12 year old Poulan/Weedeater riding lawn
American Yard Products (AYP) is the manufacturer and the part number is: 142829 the part the part description shows sub= 145775.
Posted on Oct 14, 2010
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
Spark plug size
Take the spark plug out of the mower and look on the side of the plug and it will tell you which plug is needed to replace it with.
Jun 21, 2014 | Poulan Pro 22" Self Propelled High Wheel...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Mower is puttering and spark plug is burning out frequently
Hi lutbarajas--
If the engine's plug is continually fouling, you may have an improperly rated spark plug. It sounds to me like the plug you have in the mower is burning too hot. Take the plug to your local lawn and garden supply shop and see if they can size a cooler burning plug for you. If the plug is original, and you have never tinkered with the carburetor adjustments, the plug may just need replacing.
--Hope this helps.
Oct 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
71 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
