Question about Refrigerators
Red light flashing on the t316 ice maker. Could this be caused by a fault in the water inlet valve as it is not filling to make ice and the compressor is not kicking in
Posted by Christine Anderson on
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Posted on Aug 23, 2007
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Posted on Sep 03, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Ice maker is not producing ice and the control light is blinking red
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Ice maker not working. Red light is not on. Can take out circuit board where the red light is. Plug back in. Light stays light for about 3 minutes, then goes out. What may be problem?
ICE MAKER not making ice:
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Mar 07, 2015 | Refrigerators
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
THE WATER NO STOP IN ICEMAKER MOD GSS25SGM GE
Improve the FixYa experience for everyone by voting.
Suggested approach to fixing your problem:
Your ice maker is designed to fill with water for 6 to 8 seconds. Depending on your city water pressure, anything longer than eight seconds will overfill the ice tray and either over flow the ice maker or create cubes that have difficulty ejecting.
There are two basic issues that commonly cause an overfill condition.
  • The first is an ice maker that is sending power to the water inlet valve for a period longer than eight seconds.
  • The next problem which is the subject of this answer is a water inlet valve that is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to imperfections in the valve, it is closing in a delayed fashion.
How to Diagnosis:
The easiest way to determine if your water inlet valve is the culprit, is to install a meter volt meter across the leads of the water inlet valve.
  1. Set the voltage range for 110v.
  2. Manually cycle the ice maker and watch the meter.
  3. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker.
  4. Note the difference in time between when the voltage is cut from the valve and when the water quits filling the ice maker.
  5. If the water shuts off immediately when the voltage is removed, the valve is likely operating correctly.
  6. If this is the case, it is likely that the voltage will be applied to the valve for a period of time greater than eight seconds.
  7. This generally indicates an ice maker control problem.
However, if the voltage is removed from the valve and it continues to fill, the valve is likely at fault. This indicates that due to particle build-up or mechanical failure the valve has lost its ability to shut immediately. In that case, simply replace the valve and it should fix your problem.
May 13, 2012 | GE Refrigerators
MSD 27548DR* Water leaks from back when Ice maker is filling with water
I was answering another post and this post appeared after my last post. My sincerest apologies for not seeing it long ago. The symptom your describing is caused by the inlet water valve bypassing water when it supposed to be off. This can be identified by reaching back behind the icemaker and squeezing the rubber fill tube. If it is frozen solid with ice the inlet water valve is bypassing. The inlet water valve assembly is in the back of the unit behind the fiberboard panel in the compressor / condensor coil area. There are 2 electrical connectors and 3 plastic tubes connected to the water valve. When changing the water valve do a one for one tube swap so as not to have the ice maker filling when you select water in door.
The inlet water valve is item 4 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46544&diagram_id=28489316#d28489316
Thanks for choosing FixYa,
Kelly
Mar 13, 2011 | Maytag MSD2758GEW
Ice maker does not produce ice, it was clogged with ice. so i fixed that . the tube coming down from the top was what was clogged frozen . red light is flashing twice repeatadly. need info to fix. thank...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker dosenot make ice will make if i fill
You have a bad water inlet valve OR frozen fill tube caused by a seeping water inlet valve (bad valve) .The water valve , is the piece the line from the wall connects to .
Aug 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
