I assumed I had a bad turntable motor. I removed the turntable motor from the unit it was in, and replaced it with a motor from a known to be working unit of the exact same model. The turntable still did not spin. Just to double check I put the motor I believed to be bad in the working microwave, and it spun the turntable. This leads me to believe that it may be a wiring issue.
How do I gain access to the control panel to check/replace the wiring? It appears that it would just pop off, but it has not been that simple.
Thank you for the reply. I did check the coupler. I tried the coupler from the known working microwave with the motor from the known working microwave on the broken one, and it still wouldn't work. I had voltage coming through the wires when the microwave was on, but I will have to double check how much. Once i saw voltage on the meter, I just assumed it was the motor.
