Question about Cooktops
I have a GE profile builtin gas cooktop (JGP636WEV4WW).Need Surface Burner Valve Part # WB21K5031 & cannot locate one.GE has told me to check the internet and look elsewhere (great customer service),
Any replacements or work around that one may know of? Thank you.
Posted by DONALD P CASADONTE on
5 Related Answers
csmock132
Clint Smock
  • 4669 Answers
SOURCE: EGR valve code initiated check engine light.
If you are getting an Insufficient EGR flow code, it is likely the DPFE sensor is bad or the EGR ports are plugged in the Intake. Very rarely do these trucks actually need the valve replaced. But it is located on top of the engine,under that plastic cover that covers the throttle body. It is round, about 3 inches in diameter. It has one vac line going to the top of it and a metal pipe from the exhaust manifold going to the side.
Posted on Mar 09, 2009
ROB
  • 858 Answers
SOURCE: location of check valve on 2001 Dodge ram
in the hose that gos into the engine rocker cover
Posted on Jul 18, 2009
Anonymous
SOURCE: Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Posted on Sep 29, 2009
Dennis Koenig
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
Anonymous
SOURCE: pcv valve location
volvo s80 y reg 2.4 runs ok little bit lumpy tickoover when warm but very loud whistling noise take dipstick it stops but very big suction from tube not pressure it is not breather box under manifold
Posted on Mar 12, 2010
GE Profile Gas cooktop burners blow out
This sounds as though the pressure is too high.
Feb 11, 2015 | General Electric PGP953DETBB GE Profile...
After cleaning the cooktop surface the "clicking"
I just solved the continuous sparking in my gas burner. I removed the control knobs and the rubber below those knobs. Gave the rubber and the area below it a good clean using kitchen and bath cleaning wipes that I bought from Coles. The key is to remove the water and grease from the rubber and the area below it. Good luck!
Mar 24, 2011 | GE Profile JGP636 Gas Cooktop
GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jul 01, 2010 | GE Profile JGP636 Gas Cooktop
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Dual Surface Selector Switch
more common is the dual switch to be bad, but it is possible that the elemnt itself has burnt out, usually a 5 yr warr on the elemnts under glass
Nov 08, 2008 | GE Profile JP930 Electric Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Oct 26, 2007 | GE Profile JGP636 Gas Cooktop
Cooktops Logo
157 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
