Question about Home Security
How can I lock my hardliner mini safe with my code it gives me the green light but it doesn't lock the safe at all please assist and advise accordingly. Regards Sran
Posted by Stan Prins on
Vincent Migliore
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
Be sure the safe door is held in tightly enough for the sensor to register it is in the right position for the lock to engage when you are pressing the "close" key sequence.
Posted on Oct 09, 2019
5 Related Answers
Anonymous
  • 384 Answers
SOURCE: LOCKED KEYS INSIDE A HARDLINE SAFE
Do you expect us to read minds?
Posted on Jul 16, 2009
alba567
  • 4 Answers
SOURCE: I have a Electronic Hardline Digital Safe. I have...
inside the safe door near the hinges there is a red button. Push it and the "proceed" light on the top right of the keypad will come on. enter your new code and "A". That's all.
Posted on Jul 12, 2010
Anonymous
SOURCE: Forgot code to open hardline electronic safe
Change code to open hardline electronic safe
Posted on Sep 08, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I own a Honeywell safe digital 1.06 cu #2072 when
If you are using the key, you don't need to enter a code. To open with the key only, please do the following:
1. Remove the key lock cover located beneath the digital keypad.
2. Insert one of the Emergency Override keys (2 included) into the bypass lock and turn to the left.
3. Pull the handle up and pull open the safe door.
I apologise if I have misunderstood the question. If you are unable to open the safe using either the key OR the code rather than the key AND the code, please post back and I will try to assist you further.
Regards,
BElectric
Posted on Dec 05, 2010
Anonymous
SOURCE: We have a Sentry safe
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Posted on Feb 02, 2011
I bought a house and have a hardline safe is there a way to reset the safe password. .
User override key to open safe.
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
May 03, 2011 | Locks & Locksmithing
I have a Hardline Electronic Digital safe. The battery apparently went dead and I lost the key. Please help
well -- if you have lost the key, you can take the serial number of the safe into any loccksmith shop and they will be able to call the safe company and get the key code and cut you a new key.
also -- look on the front of the lock cylinder itself and see if there are any numbers imprinted on the lock and with those numbers the locksmith might also be able to look up the key code and cut the key. the cost of this will be around 15 dollars.
c...
Jan 03, 2011 | Safe International Digital Electronic Safe...
May 20, 2010 | Safe International Digital Electronic Safe...
I LOST THE MANUAL, HOW TO RESET THE NEW NUMBER?
I LOST THE MANUAL FOR THE 'HARDLINE' DIGITAL ELECTRONIC SAFE. HOW TO RESET A NEW NUMBER?
Dec 22, 2009 | Safe International Digital Electronic Safe...
Digital Electronic Security Safe S2120.
You will probably have to call a locksmith who specializes in digital safes, or you can contact hardline and give them the serial no. of the save and proof of purchase to get the code or key. You will probably need proof of purchase for the locksmith to.
Sep 18, 2009 | Kitchen Appliances - Others
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Home Security Logo
151 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
