Question about Olympus Cameras
Changed the batteries in my Olympus 560 uz and now getting battery empty the new batteries are fully charged can you tell what the problem is.
Posted by Richard Holland on
5 Related Answers
Anonymous
SOURCE: Olympus 550 UZ battery
I have been using energizer lithium batteries, and get well over 500 pictures (mixed flash/no flash)
Posted on Mar 06, 2009
Randy Morton
  • 479 Answers
SOURCE: My Olympus 560 UZ won't turn on
make sure batteries are in correctly, may want to try lithium batteries, but if camera does not power on at all.. it is repair
Posted on Apr 07, 2009
Anonymous
  • 240 Answers
SOURCE: "Battery Empty" Message
olympusamerica.com/files/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
this might be useful for u
Posted on Jun 18, 2009
HarryHarley
Harry
  • 343 Answers
SOURCE: my olympus sp-310 camera shows empty battery but I
Are you sure you put them in with the correct polarity facing the right way. Its a common mistake.
Also try a "known" set of batteries just to make sure.
Good luck
Posted on Jan 21, 2010
Anonymous
SOURCE: How i can mount a new battery cover on Olympus
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Posted on Aug 19, 2010
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
Camera wont turn on
1. Are you sure the battery is fully charged?
You can charge the battery by connecting the Olympus USB cable to the camera and computer.
Or using the delivered wall charger. When charging the orange LED on the camera should light.
When fully charged, the LED is off.
2. If this does not help you, check if your battery is well seated in the camera.
3. Check if the battery is faulty by replacing it by another one.
See users manual page 9, 12 and 53
May 25, 2011 | Olympus SP-500 UZ Digital Camera
How i can mount a new battery cover on Olympus SP-560 UZ
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
I need a new battery cover, where can i get one?
a battery cover can be bought at any olympus camera center or at walmart.
Mar 12, 2010 | Olympus SP-560 UZ Digital Camera
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Sep 28, 2009 | Olympus SP-550 UZ Digital Camera
Apr 06, 2009 | Olympus SP-560 UZ Digital Camera
you may want to use lithium batteries... i find the rechargeables in most cameras to not last as long... also you may need to clean the contacts in the battery compartment with alcohol and let air dry
Jan 04, 2009 | Olympus SP-550 UZ Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
