Question about Dishwashers
CDA Dishwasher WC140-IN No Power No Lights
D/W has no power, no lights (therefore no error codes). I think it died in between usage, as the D/W was empty when problem spotted. D/W plugged in to spurred socket, but power is there. Changed fuse, no difference. Used the fuse from D/W in another appliance, and it works. So fuse and socket okay. Checked plug, all okay. No loose wires. No RCD trip on main board, otherwise other sockets would be dead. I'm sure you can tell from the model, this is integrated and I have not had the entire unit out, but assume power cable from plug to unit is okay and not compromised. I'm guessing I am going to need to remove the front panel to get in to the door section, but I have no idea what to look for or what to test via a multimeter.
Posted by Moorgate on
Dan Peters
    New Friend:
  • 48 Answers
This is probably a fault with the PCB and you may need an engineer to replace the part.
If your dishwasher is still under warranty, call CDA.
Best,
Dan
Posted on Oct 14, 2021
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: canonmp830
Have you checked the fuse[s]? You don't mention your location so I cannot comment of what protection devices that may be involved. UK has fused 13amp wall plugs for example.
Posted on Aug 21, 2007
Anonymous
SOURCE: Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
Posted on Aug 11, 2008
Anonymous
SOURCE: loud bang and fusing dishwasher
chucked it !!
Posted on Nov 16, 2008
Anonymous
SOURCE: Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Posted on Jan 09, 2009
Anonymous
SOURCE: Total dead, no power? Changed fuse in plug and
This is quite an easy problem to fix. Whats happened is the water heater has overheated and tripped the power as a safety measure.
Take off the Left hand cover, there are 4 torx screws. You will see the water heater. with what looks like 2 circular teminals held on the side with a metal strap.
these are one shot thermal cut outs. the same as on a tumble drier.
Tassimos are over engineered and really only need one thermal cut of. if there are no lights on the front, the brown wire has tripped. if there is light and no heat the blue wire has tripped.
What I did was swap the brown wires over to the trip that had the blue wires on, so you still have a thermal trip. and bridge the blue wires together and taped them up - voila it works again. DO NOT CROSS THE BROWN WITH THE BLUE> BOOM!
to do the job properly take off the thermal trips and go to an applicance repair shop. of they dont have them on the shelf i would suspect they can get them they are very generic. try not to lose too much of the white thermal paste as this helps with the cut off. if you do lose some its the same as used on CPU heatink compound. put them in and replace the strap and re assemble.
FIXED
Posted on Sep 08, 2009
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
3helpful
7answers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Maytag dishwasher error code 96?
Try killing power to the unit, typically this is at the breaker box but from time to time it may be connected to another circuit in the kitchen that may have GFCI circuit. Make sure the GFCI is not tripped killing power.
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
There is no instruction manual for my CDA cw497 dishwasher,how do i start it please?
I think you should ask the dealer who sold the item. I googled for the manual but I was unable to find it.
Fog Lights For BMW
CDA wc370 dishwasher wont start,
Clean latch mecanisim ,,,,Close door fully , with a bang ,,
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 • Dishwashers
1helpful
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • 2helpful
    Fisher paykel dish draw
    Turn the power off to your dishwasher for about 30 seconds by flipping off the circuit breaker in your home's breaker box. When you turn the breaker back on it will have reset the dishwasher and should begin working just fine.
    Aug 24, 2008 • Dishwashers
    Open Questions:
    Dishwashers Logo
    Top Dishwashers Experts
    Michael Thomas
    Michael Thomas
    Oloyede Monsuru
