Question about Alba Televison & Video
I have a alba rdvd1001xi when I contact to my tv my tv does not recognise it nothing at all shows on tv screen. Can you suggest anything
Posted by Edward Smith on
All my tv shows a a blue screen nothing else even when I press input
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Televison & Video
My Alba TV , when scanning for channels ,says no signal, check antannae, which i have by connecting a different tv, its working good , but my tv not showing any channels when even using first time ins
Check and replace the tuner inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Alba LDVD1538WDCH LCD TV
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
Alba code help
hey...Ben eye just hit ebay & there are alot of alba remotes w/codes/manuals
Feb 18, 2014 | Philips Televison & Video
I have a 5 month old Alba DVD Tv combo model number LCD22ADVD. The DVD has stopped working and when DVD input selected, instead of showing the usual DVD home screen, it now shows a bright blue screen. The...
Sometimes a dvd can be ejected manually but mostly the unit must be partially dismantled but if you try to do that you will invalidate the warranty - at only 5 months old it will be the responsibility of the supplier/retailer to cure the problem. I suggest you re-read the instructions and then contact the supplier without delay.
Then you should contact the dvd rental company and tell them what is happening.
Sep 28, 2017 | Televison & Video
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Jan 04, 2009 | Televison & Video
Tv code for Alba 14" tv
need code # for tv durabrand modle no.DWT2704
Dec 13, 2007 | Durabrand DWT2704 TV
Televison & Video Logo
35 people viewed this question
Top Alba Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
