Question about Raypak Pool & Spa
Service light comes on our Raypak RP 2100 pool heater.
Service light comes on our Raypak pool heater Model RP2100.On the back of control board shows overtemp fail. What is the remove and replace procedure for this component? Thank you, Ken
Posted by info90045 on
Anonymous
    New Friend:
  • 139 Answers
This usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • Paul Robles
    Paul Robles Apr 21, 2014
    how do I acertain if it's a component problem
I need to now how clen a filter on my rp2100 digital
rp2100 is a pool heater by raypak it has no filter. you need to clean the filter whatever type it may be. sand/de filters can be taken apart and the medium takin out and replaced, while cartridge can be taken out and sprayed with a hose and put back.
Sep 28, 2015 | Pool & Spa
Plt code comes on display ?
Plt means pilot light failure. the heater has failed to ignite. either the ignition unit needs cleaning or replacement or the pilot light valve where the flame is, has got dirty and needs a service.
recoment you get a heating service engineer to have a look at it.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
I have a RP 2100 Raypak Pool Heater Model number C-R185-EN installed about 1996 and used very little through out the years the front service light is on-- red --the back circuit board fault shows a sensor...
The part number for the thermistor for your heater is 005299B, officially called the temperature sensor IID it is also refered to a temp sensor or temp sensor kit.
John
Jul 09, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have a 010253F replcement kit for a Raypak model 335a heater. Need wiring instructions.
Go to the RayPak web site. They have a pdf of the instructions for replacing the board with what you have.
Sep 04, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
TA6 or tab code rp2100 digital pool heater
yes that tab means you heater pc board is bad you need to replace it the code tab will not be in inside of the heater door with the other codes its only meant form service tech if you need a pc board i can get you one at a good cost 3614619875 durans pool service
May 03, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
1,411 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Marvin
Marvin
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
