Question about Samsung Office Equipment & Supplies
I changed the cartridge for SXC 6345N Samsung printer. There is a message that says "Toner Sensor Error" what can I do to fix this problem?
Posted by Tesfaye A Aleme on
D C
    New Friend:
    Problem Solver:
  • 15 Answers
I googled your situation and I found this. From what I read this is a problem with the drum or a sensor. Good luck.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.copytechnet.com/forums/samsung/96387-scx-6345n-toner-sensor-error.html&ved=2ahUKEwi8pbj0kILlAhWOl-AKHZVkCF0QFjAAegQIBBAB&usg=AOvVaw3AUZb4VREIf13vy3yyR1vO&cshid=1570176012398
Posted on Oct 04, 2019
5 Related Answers
Anonymous
  • 1665 Answers
SOURCE: 543K Toner Sensor Error
Check toner lock lever is in position - Seek attention of service person if restarting the printer does not correct the problem. See our How to Guide
Posted on Aug 12, 2008
Anonymous
  • 446 Answers
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Posted on Aug 16, 2008
Jeff Hughes
  • 97 Answers
SOURCE: Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
Anonymous
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
Anonymous
  • 35 Answers
SOURCE: The printer message window says: Check Toner
check ur cartridge.. it might wrong place
Posted on Oct 24, 2009
Toner supply error
hello sir...
when u face this problem then right side cover open and then close cover ur printer start again printing. otherwise open ur toner and again fix ur toner and then start ur printing
Dec 18, 2013 | Samsung SCX-6345N Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Scx-6345n toner supply error
DID YOU RESET THE PRINTER TONER ERROR? CHECK YOUR USER GUIDE.
Feb 15, 2012 | Samsung SCX-6345N Printer
CLX 2160 Message: Deve Home Sensor Error. What can i do to correct it.
There could be two problems
A minor error occurs and the machine is waiting an error to be cleared. Check the display message, and solve the problem referring to Understanding display messages, see page 11.3.The toner cartridge is low. Order a new toner cartridge; see Ordering supplies on page 12.1. You can temporarily improve print quality by redistributing the toner. See page 10.4.
For referring this page numbers, please download the manual from this link.
http://downloadcenter.samsung.com/content/UM/200812/20081215154056890/Guide_EN.pdf
The error message, which you have told me, not in the error message list. I think there is an internal failure for the printer. It is always recommend servicing your printer with authorized service centers. If the error message is not in the error list, owner cannot repair but, technician can repair the printer. I hope this information is useful for you. Thank you.
Apr 19, 2011 | Samsung CLX-2160N All-In-One Printer
Tonner exhasted error in sumsang sxc 4300 printer
You need to replace the toner cartridge with a new one or a recharged toner cartridge that suits your model printer. Recharged or re-manufactured toner cartridges are cheaper than new ones.
Dec 11, 2010 | Samsung SCX-4300 Monochrome Laser...
I'm trying to install a new toner cartridge into my printer (yes, it's a Samsung cartridge, not an imitation) and the printer won't recognize the cartridge - it keeps giving me an error message saying,...
most toners have a wing or *** or? that contacts a sensor in some way when the lid closes to tell the machine a toner is present. ive had these pieces broken off on new toner or the toner sensor may be disloged from its seat. check around the perimiter of the lid to find the sensor then see if anything is present to trip the sensor. if its broken off stick a q-tip in the sensor that will get you printing til you can replace the part
Nov 04, 2009 | Samsung ML 2010 Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
