Question about Samsung Cell Phones
My Samsung wa476dshawr keeps having error dc show up. Then when I reset it it starts all over
Posted by Cynthia Owsley on
2answers
I have a top load samsung washer and for a while now it will give me a dc error code and won't spin all the water out of the clothes? Need help thank you
If your Samsung top loader is starting to spin, but stops after a minute or two, and starts to fill up with water again... and then after 3 times of doing this, it errors out with a DC error code, the problem could very well be with the support rods. The springs in these rods will get weak over time and allow the drum to become unbalanced during the spin cycle. Fortunately, the 4 support rods are very easy to take out and replace. And sometimes, they just need to be greased properly. I had a service technician replace my support rods, but he didn't grease the top and bottom bushings first, so my machine still wouldn't spin properly. After he left, I pull one of the support rods out, cleaned out the dried up grease where the support rods lock in, and applied a liberal amount of white lithium grease to the top and bottom bushings on the support rod. I then put it back in. I did the same for the 3 remaining support rods. Now the support rods were able to move very freely in their holders, which is necessary during the spin cycle. My machine now spins like it is supposed to and I don't get the re-fills and DC error code anymore. This webpage, http://www.appliancepartspros.com/samsung-assy-damper-owm-dc97-16350c-ap5623264.html , contains a video that shows you how to remove, inspect and grease your support rods properly. It is not hard to do, but can be a bit messy. Have gloves and/or cleaning rags handy. And if you do need new support rods, this place has them cheaper than you can get them from Samsung!!!!
Samsung washer dc error
My Samsung Aquajet Washer has a DC error and when I pause it and start it again,the time keeps going up and doesn't stop. I don't know what to do!! Please Help
2helpful
2answers
Lifespan treadmill has a dC-1 code
Reset the error follow the steps. God bless you
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
1helpful
What does dc Flashing on my Samsung aqua jet dryer mean?
A "dc" error occurs when a Samsung washer is unable to spin due to an unbalanced load. Redistributing the items inside the washer and pressing the "Start/Pause" button typically clears this error
10helpful
My samung sgh-t239 just keeps restarting and wont let me do anything ..it just shows T-239 on the screen and starts over i took the battery out and put it back in and the same thing...nothing...it just...
I had to reset my phone: http://forums.t-mobile.com/t5/Other-Samsung-Phones/Samsung-T239-Reset/td-p/184573;jsessionid=3AB214FE95DEC1110DEE3FC25C5C7FF3
73helpful
6answers
33helpful
13answers
System error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Michael Thomas
Michael Thomas
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
