Question about Samsung Heating & Cooling
Samsung AQV09NSD red and green lights blink and turn off split unit
Posted by Keith Hays on
5 Related Answers
Anonymous
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
Anonymous
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
Anonymous
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
Anonymous
  • 64 Answers
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
Posted on Aug 15, 2009
Anonymous
  • 92 Answers
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
Posted on Sep 07, 2009
Samsung AQV24NSGN red and green light blink
The blinks are a code. If 3 red blinks, could be power board.
Apr 13, 2014 | Heating & Cooling
Lg split system
my home outside ac unit isn't blowing out any air the coils are clean yet for some reason the freon leaks out from the base out to the pipe. what seems to be the problem amd how can I fix this 7_7_2013_2_24_50_pm.jpg
Jul 03, 2013 | Heating & Cooling
When i start the a/c indoor unit working and after 1 minute of the indoor unit and blinking the green and red light.
Green blinks indicate communication to outdoor, but red light indicates communication problem. Check PCB.
Oct 16, 2011 | Samsung AS18A6RB Air Conditioner
Split a.c.1.5.ton, yesterday night stopped. one red light and 2 green lights blinking. a.c.not working. power is coming. what to do ?
Somewhere on the cover or the circuit board there should be a chart that tells you what the different light combinations mean. Look around inside the unit and try to find the codes and you can also check the owners manual.
Sep 05, 2010 | Samsung Heating & Cooling
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
108 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
