Question about Maytag Dishwashers
Model mdb-3. Turned on Friday to Monday. Dishes were not cleaned, water in the bottom - the electrical circuit ok. Is there a reset on his model?
Posted by Paul Johnson on
5 Related Answers
Mike
  • 677 Answers
SOURCE: dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Posted on Apr 01, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: My Maytag dishwasher Model # MDB-3 will not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 03, 2009
Anonymous
SOURCE: Maytag Dishwsasher Model MDB-9
The Switches do not oprate when you press them. What can be the reason?
Posted on May 31, 2010
Anonymous
  • 37 Answers
SOURCE: Maytag dishwasher Model # DWC4910AAW
msbcox -- Check for residue in the strainer under the lower washbar. Remove the lower dish rack. Strainer is under washbar. Sounds like it is not draining properly. Write back if you need more help. -- SWT
Posted on Aug 04, 2010
matt lyall
  • 38 Answers
SOURCE: water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Posted on Nov 02, 2012
Our keurig brwing machine has been soeweding hot water and been dangerous. could you tell how it can be replaced and what phone number i should be calling.
Some of the Keurig machines were recalled for this issue They are Model number K10 (formerly identified as B31) produced prior to July 2014. c You can call toll-free at (844) 255-7886 Monday through Friday from 8:00 a.m. to 8:00 p.m. (Eastern Time) and Saturday and Sunday from 8:00 a.m. to 3:00 p.m. (Eastern Time)
I have attached a link to the site. I hope this helps.
Jan 05, 2015 | Keurig B100 Coffee Maker
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
HI THE 3 INDICATER LIGHTS WERE ALL ON SHOWING THAT THE HEAT SHOULD HAVE BEEN ON FULL CAPASITY!!BUT THERE WAS NO HEAT BLOWING OUT OF THE GRILL!!
Not an unusual problem with any electric fireplace heater. I suspect the overheat circuit has shut the heating element down. Or the element has burned up (that's not unusual either).
In any event, turn the fireplace OFF and unplug it. Wait 30 minutes before plugging it back in. During that time, the overheat circuit may reset itself. If that fails to solve the problem call The Technical Service Dept of Dimplex USA at 888-346-7539, Monday - Friday, 8:00 a.m. - 4:30 p.m. EST. If it ends up needing parts, you can order them at that time.
Have the Model # and Serial # of the fireplace, handy. As you will need to provide that information to them, as well as the date of purchase.
Mar 02, 2011 | Dimplex DF3003 Electric MidSize Heater
Model MDB 7600AWQ It is not cleaning dishes well and the bottom water 'slinger' is not rotating. We disassemble the lower assembly and cleaned extensive soap scum and hard water deposits. Lower slinger is...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
My GPS cannot detect the satellite signal.
Garmin says:
If your GPSMAP 60CSx will not acquire a satellite signal when outside with a clear view of the sky, please try the following:
  1. Click here http://garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the onscreen instructions to install and update your unit
  3. Once updated allow for the device to set free from obstructions for 20 minutes to acquire satellites
If this does not work then we suggest doing a master reset with your device - Note: A master reset will erase all waypoints or favorites and will restore your device to the default factory settings. To perform the master reset please do the following:
  1. Turn the device OFF
  2. Press and hold Quit + Menu + Out + Power
  3. The device screen will then flash and will power on
  4. Leave the device turned ON with a clear view of the sky without moving it for approximately 30 minutes so that it may acquire satellites
If still unable to acquire satellites, contact Garmin Customer Support via one of the methods below:
North America - Consumer Products (for all Garmin products except Apollo aircraft)
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
E-mail Product Support
Europe - Consumer Products (for all Garmin products except Apollo Databases)
Austria For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 43 (0) 3133 3181 0
Website
Belgium For all Garmin products except Aviation.
Friday: 9:00 AM – 15:00 PM (GMT/UTC +2)
Phone: 00 32 2672 5254
Website
Denmark For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM Central European Time (GMT/UTC +1)
Phone: 00 45 4810 5050
Website
Finland For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 16:00 PM (GMT/UTC +3)
Phone: 00 358 19 311 001
Website
France For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 33 1 5517 81 89
Website
Germany For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 17:00 PM Central European Time (UTC/GMT +1)
Phone: 00 49 898 58364 880
Website
Italy For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 13:00 PM / 14:00 PM – 17:30 PM (GMT/UTC +2)
Friday: 9:00 AM – 13:00 PM / 14:00 PM – 16:30 PM (GMT/UTC +2)
Phone: 00 39 02 3669 9699
Website
Portugal For all Garmin products except Aviation.
Monday – Friday: 09:00 AM – 12:30 PM / 14:00 PM – 18:00 PM (GMT/UTC or GMT/UTC +1 depending on city)
Phone: 00 35 1214 447 460
Website
Spain For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 13:30 p.m / 14:30 PM - 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 34 934 972 373
Website
Sweden For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 00 46 7744 52020
Website
United Kingdom For all of United Kingdom users and customers in unlisted countries in Europe, Africa and Middle East
Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
Phone: 00 44 808 238 0000
Website
Oct 08, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Dishwasher
I have seen this problem before on a couple of dishwashers.
How are the dishes doing? Are they coming out clean, or do some of them "fail".
If you rinse the dishes before putting them in the dishwasher, it may be hard to detect "failure" to clean. Try not rinsing the dishes once and run them through a cycle. My guess is that the "failure" rate will be high.
The problem I have seen is that the dishwasher water input filter is either clogged or the water-full sensor is "telling" the unit that there is enough water in before it actually fills properly.
So, some water can get in, but not enough to properly wash the dishes and dissolve the soap.
On the appliance repair sites they have parts breakdown details and what you are looking for is an input valve assembly -- the point just after the water line connects to the dishwasher.
Now the valve may be OK, but the feedback system could be bad.
(On a Bosch dishwasher the valve IS the feedback system and the filter.)
Any filtering or "water full" signal will feed back to that valve.
If you get inside that front lower panel, be sure to turn the electricity off first 'cause if you get crosswise in that area you could end up with a 'shocking' experience!
good luck
May 09, 2009 | Dishwashers
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
Missing pieces
Product WarrantyFor issues or questions regarding your household appliance's warranty, please use the following.
Phone Number: 800-231-9786
(Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Email: [email protected]
Parts and AccessoriesFor parts and accessories for your household appliance, please visit our partner, Fox International, or use the following.
Phone Number: 800-738-0245 (Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
Product RecallsFor issues or questions regarding your household appliance's warranty, please use the following.
Product Registration:http://www.prodprotect.com
Other questions, please call 800-231-9786.
Dec 02, 2008 | Kitchen Appliances - Others
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve
Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms
There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Detergent cups
Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
168 people viewed this question
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
