Hi
Thanks for using FixYa. First of all please check that the
speaker cables are not damaged and the connections are secure. Reduce the
output level from any external components connected to the music center. Make
sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1
jack and the multi-pin connector on the other end is firmly seated in the Accustoms
module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers
to the Accustoms module. To restore communication between the music center and
the speakers turn the music center off for ten seconds, then on again. Check
the connections for any external components. Make sure to select the correct
source for the desired input. Be sure the CD is placed correctly, label-side
up, in the magazine, and the magazine is inserted properly in the music center.
Increase the volume. Check to see if MUTE is lit on the display. If it is,
press the MUTE button on the remote control to un-mute the sound. Disconnect
any headphones. Connect the FM and AM antennae. Check to see if the play symbol
in the display is lit. After pressing the CD key, wait a few seconds before
pressing PLAY. Make sure the magazine is properly inserted. Check to see if
there is a disc in the magazine, label-side up. Display shows a flashing box
for a disc that is label-side down or cannot be read. There may be dirt or dust
on the CD. If so, clean the CD. Eject the magazine and try loading the CD
again. A display message “E01” indicates a mechanical error. Unplug the music
center. Reconnect power and try again. If “E01” reappears, call customer
service.
If the CD stuck again as you stated in your earlier
comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside
down so that the "Manual Magazine Release" is in your upper right
hand. Locate the two small rectangular "Open Slots" on the side. You
need to use the top slot. Use the screwdriver and push the little "U"
or "Y" Shaped metal upward which is just below the manual release. The
magazine will come out.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
On the Bose Lifestyle 20, if you unplug the unit and flip it over, look for the words Manual Magazine Release(viewing the bottom with cd opening facing you look top right). Try using a slim jewelers screwdriver to release magazine. If CD is still stuck, try to see if it will play(with magazine partly out). If it reads E (error), reinsert magazine and then press eject (the manual says it will stop the cd and put it back in magazine.
Here is the manual for the Bose lifestyle 20.Click the below link.
http://products.bose.com/pdf/customer_service/owners/og_ls20.pdf
Hope this helps
Thanks
Smith.
Push in gently and it will pop out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
There seems to be nothing to push to release the magazine, when pluged in all I get is a buzz.
My Bose will not release the magazine, I have tried manual realease, but nothing happens. when pluged in all I get is a low buzzing sound??
The magazine came out, changed CD's and tried again, It still only buzz's
Any more ideas?
The magazine came out but when I tried it again (different CD's) all it does is buz
