Question about Nokia Cell Phones
Message on my Nokia 6310 asks for a simcard, it still, however, has the original simcard in it so why is it asking for a simcard?
My Nokia 6310 number is: ***********....... Note: The phone hasn't been used for some time. Incidentally, there is still an amount of credit left on the phone, how do I get the credit and why is it asking for a sim card?
Posted by PATRICIA MACKENZIE on
5 Related Answers
Anonymous
SOURCE: Phone disabled PHONECODE
hi i have a problem.. my siemens sk65 casing was damage it has a crack in the left side on it.. can i change the casing?.. where can i order a new casing for this?
Posted on Apr 19, 2008
Anonymous
SOURCE: Nokia 6500 slide - RESTRICTION CODE
hi,
I have Nokia 6500 Slide locked to UK Orange Network.
IMEI Number is 352027027919833
Kindly help with a Unlock code.
Thanks. CAISER NOMAAN
Posted on May 24, 2008
Anonymous
  • 282 Answers
SOURCE: Nokia 3120
Write here your phone's IMEI number here. To see the imei press *#06# in your phone. It will be of 15 digit.
Posted on May 25, 2008
Anonymous
SOURCE: no simcard eventhough simcard inserted in MOTOROLA ROCKER E6
first remove the sim card and then switch on the phone... then choose antenna on... after a few seconds you will see emergancy only on your screen ... turn off your mobile and insert the sim and switch it on again ... this solved my problem ... but this is not working on my cell now.. does anybody have a solution?
Posted on Jul 12, 2009
Anonymous
  • 20 Answers
SOURCE: i have digicel sim card and its asking for the PUK
you can find ur Puk number at back side of your plastic sim card .it will have 8 digit.
Posted on Apr 24, 2010
1helpful
Nokia 1280 puk code
PUK code is related to your network operator, call the customer care of your network operator. They will ask you your 19 digit sim card number which is given in your simcard itself, firstly take out your simcard from your mobile and then note it down again put it inside the simtray, and call to customer care from any other phone of same network(idea/airtel/bsnl...etc).Ask them for PUK code they will ask you for the 19 digit simcard number and they will give u a code, put that code and follow the instructions provided by them
Unlock nokia 6310 from orange
hi you can use codes to unlock your nokia 6310 .you can get the codes from this site unlocking4free here they ask the imei number of the mobile .finally they will send you the codes to unlock your mobile at free of cost.
Nov 29, 2011 • Cell Phones
2answers
Says message ending failed every time i try to send a message... I have full coverage and my plan is up to date.. is this a phone problem or if i buy another one will it be the same issue.
Each telephony provider has a special phone number (called "Message Center") which must be set accordingly before you'll be able to send messages. Call your provider's ClientService and ask them which is the number that must be set.
For example, my telephony provider COSMOTE (in Romania) has +40766000510. Practically, without this number set in the message settings section, no message(s) could be sent!
I have put the security code on and i forget my code now i switched off and on my mobile with other simcard it is asking for security code i am using nokia 1100
Just put back the original sim first that comes with the mobile. Remove the security code. Then try to replace the sim. If the new sim will ask again the security code your mobile is not open line. So it will just only work to the original service provider.
Mar 09, 2011 • Nokia 1100
4helpful
3answers
My phone model is nokia 5800d-1 it's locked now and I need a puke code to unlock it how can I find the puke code?
Hello
Finding a PUK (Personal Unblocking Key) number is not tough job. To find a PUK code all you have to do is call up on the customer care number and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care of your service provider are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to but a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number.
Hope it helps, if so do rate the solution
2answers
Message sending problem with my nokia-E63
Check your message centre number .It may be changed please call your service provider and ask them your message centre number.
2helpful
Nokia 5130 starts up with message "start up mobile without simcard"
that wil happen if you try to start it up without sim card,
put the sim card again and open it, if it asked again, then choose "NO"
that will do it.
Most of this model made by nokia, can be open and access the files in the phone memory without simcard,
Just choose "NO"
1helpful
My pin code is blocked and i forgot my puk code
Finding a PUK (Personal Unblocking Key) number is not tough task. To find a PUK code all you have to do is call up customer care and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the cell phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to get a new simcard. This might happen that your phone might ask you for PUK2 after you enter your PUK number.
Sep 02, 2009 • Nokia 6600
2answers
Puk code for simcard
Puk number of the phone is asked when you enter the wrong phone unlock code 3 times. It is possessed by the manfucaturer. The only thing you can do is to produce the original receipt of purchase at the nearest nokia store and they will unlock it for you. If you purchased through e-bay that recipet will also do but they will charge you a small amount to unlock it.
Cell Phones Logo
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
Kolbrun...
matt
matt
