Question about KitchenAid KUDS01DJ - Multiple Color Dishwasher
Kitchenaid model kudso1dj blew a fuse and will not respond after a new fuse was installed in the fuse box
Posted by dschanou on
Roipatrick
  • 906 Answers
Good day,
hope this link below will solve problem.
kitchen
Posted on Aug 04, 2010
Kitchenaid dishwasher control panel not responding .there is power
Try flipping the break in fuse box. It may reset control panel. good luck
Jun 22, 2017 | KitchenAid Dishwashers
After installing a new radio, everything worked fine for couple days. Why are my dash lights, stereo, and tail lights not working?
you blew the fuse, in the fuse box.
or it blew again, do to shorts you introduced or IT, manifested.
Apr 16, 2015 | 1993 Geo Tracker
Polarity was reversed when jump starting vehicle installed new battery & no power to anything mechanic said fuse got blown.What fuse,where it is located & cost of it.
Hard to say without make, year, and model-but check all fuses in the power distribution box under the hood- ignition, alternator fuse, etc.-all of them, the small ones and the maxi-fuses. All fuses are pretty cheap. If you still have nothing, you may need a wiring diagram to check for fusible links that would be power distributors right off or near the battery. Fusible links work much like a fuse, and most have been replaced by maxi-fuses, but many vehicles have both. If there is a designated main fuse, it should be in the distribution block or box under the hood.
Feb 06, 2013 | Cars & Trucks
I have a '00 Nomad 1500 Fi. I had a starter switch burn up and blow the main fuse on the solenoid. I replaced the switch and fuse and away I went. 2 weeks later the ignition fuse blew, and blew, and blew,...
Hi, Rileyjr12 I read your novella I do not understand what you are trying to say, why are you telling me what the problem could be without stating what the problem is today try expressing your issue in the form of a question that includes one or more of the following words:
Who-What-When-Where-Why
Finish your sentence with a question mark instead of a period. If English is not your primary language then write the question in your native tongue I will translate and respond in same. Finally, make sure you include the Year-Make-Model of your motorcycle or scooter. Please click on the "comment" word below and provide this information in the box provided with no limit on words and after you post it, a comment alert icon appears on my screen that will allow me to respond to your original question in another comment box below yours.
Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 27, 2017 | 2001 kawasaki VN 1500 Vulcan Classic
Think I have blowon the motor on my American pruchased Kitchenaid
Perhaps you may be lucky to have blown a protection diode within the circuit seek pro advice
Apr 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
95 toyota carmy fuse has blown fuse in the car. when i was installing a new cd player wires touched and the clock light blew where should look for the blown fuse
under the dashboard its probably a 15 amp fuse . there should be a diagram on the fuse box that says what is what .it probably also blew out the cig. lighter ... good luck
Oct 07, 2009 | JVC KD-G210 CD Player
Trying to access the pump and motor section
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Jan 08, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Aug 15, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid KUDS01DJ - Multiple Color Dishwasher Logo
216 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
