Question about Locks & Locksmithing
SOURCE: doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Posted on Mar 19, 2009
SOURCE: Problems changing a doorknob
If there are no visable screws on the inside of the door than there is a cover plate that can be removed by prying it off with a small screwdriver revealing the screws. Please remember to rate my answer
Posted on Aug 07, 2009
SOURCE: DEADBOLT INSTALLATION PROBLEM
Did you cut the bar to the correct lenght?(the flat or square one that connects to the thumb latch or other cylinder?) Too long and you'll bind the lock.Good Luck
Posted on Sep 15, 2009
SOURCE: How do I remove the doorknob from a weiser passage
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Posted on Dec 29, 2009
SOURCE: Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Posted on Feb 27, 2010
Mar 14, 2013 | Schlage Plymouth" Georgian Entrance...
Dec 23, 2011 | Kwikset Locks & Locksmithing
Dec 01, 2011 | Hardware & Accessories
Jan 26, 2011 | Garden
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Feb 27, 2010 | Hardware & Accessories
Nov 03, 2009 | Hardware & Accessories
Mar 12, 2009 | Top Knobs M826 Door Pull
Oct 19, 2019 | Deadbolt Locks & Locksmithing
149 people viewed this question
