Question about Lands Phones
Problem with cordless phone so I deregistered it and now I am having problems registering it. I did this before and it solved my problem but it won't let me register this time
SOURCE: Phone beeping!
on some phones the beep refers to a voice mail message that has been left on your answerphone which will be left at the BT server, you can dial 1571 to retrieve the message. Other than that if you have re registered the phone correctly following the instructions on page 22 of the below manual, return the set as faulty. http://media.venda.com/btshop/ebiz/btshop/invt/cay222/freestyle2200.pdf
Posted on Jul 08, 2007
SOURCE: Deregistering a phone you can't find
I had trouble deregistering one of the phones, as it has to be close to the original base (kept telling me out of range). I found out that pressing END and #, also deregisters.
Posted on Aug 25, 2007
SOURCE: Uniden TRU8885 Register/Deregister Issue
Here's what you do:
Should work like a charm.
Posted on Dec 24, 2007
SOURCE: http://register.hp.com
uninstall hp printer driver from add/remove programme remove cable from printer reinstall hp application
in first time installation you would found that registration fourm
fillup and that time you would click on register later or do not register
Posted on Mar 29, 2008
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
Apr 16, 2016 | Uniden D1780 Dect 6.0 Cordless Phone With...
Mar 14, 2016 | Lands Phones
Jan 21, 2014 | Panasonic KX-TD7896 Cordless Phone
Jan 16, 2011 | Uniden TCX905 Cordless Accessory Handset...
Oct 20, 2009 | GE Lands Phones
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Mar 23, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Dec 14, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
May 31, 2008 | Uniden Cordless Phone
Apr 12, 2007 | Motorola Mobility MD761 Cordless Phone
115 people viewed this question
