Question about Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame
Siren Digital photo frame
I recieved this as a gift a few years ago, and can't find the instruction booklet. I have never used it.I have plugged it into a power source, but it doesnt appear to turn on. Can you help?
Posted by jennifer_933 on
5 Related Answers
Anonymous
SOURCE: 7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
Posted on Nov 09, 2008
Anonymous
  • 47 Answers
SOURCE: Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Posted on Jan 04, 2010
Anonymous
  • 214 Answers
SOURCE: the Kodak easyshare S510 frame is down
I think you have no option but to have your frame repaired by kodak, you can contact their support line at 1 800 235 6325 use ext. 14
Posted on Jan 08, 2010
jhinsincity
Julio Hernandez
  • 616 Answers
SOURCE: I have a Kodak M820 digital photo frame but my
simply a format thing, you'll have to adjust your camera to take pics in the correct format, one your photo frame can support.
Posted on Jan 11, 2010
Anonymous
SOURCE: Digital Frame Kodak EX1011 turn off after few seconde
This seems to be a known problem with Kodak digital frames. I have one and had this problem, hence me searching the net and finding this site.
Anyway, I think I solved my problem when I changed the picture transitions from random to just left swipe. It hasn't turned off since unless it's on the off schedule. I noticed it not showing anything but then I heard audio on one of the videos I had in the USB drive. This meant that it's still on but it's just not showing anything. Changing the transition to just left swipe kept it on. My guess is that some fade to/from black is messed up and kept the screen black. I've had this frame for years so maybe it's just due to age.
Posted on Sep 08, 2010
I have a siren digital photo frame that doesn't work. I have it plugged into my computer, but yet nothing happens. Also can't get it to come on when plugged into the ac power adaptor in the wall. Are
Take it back to the vendor if its new and does not work . costs a fortune to fix most times. Down load photos to a chip or use the camera chip, use the photo frame to display them.
Dec 24, 2014 | Computers & Internet
I was gifted accura digital photo frame but I am totally illerate about its function ,please guide me
U have a digital camera?Use the Digital camera take pictures with the menory stick.Take out the menory stick,plug it in the Digital photo frame to tranfer pictures.Or no menory stick,plug direct in to the digital camera to tranfer pictures.
Jun 14, 2010 | Westinghouse 7" LCD Digital Photo Frame
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
I received a digital photo frame, but no instructions. Where can
I guess I will return the digital photo frame. I do not feel that I should have to pay to get instructions for a digital item. This is ridiculous! Too much greed in the world. Why wouldn't this gift have the manual included ?
Dec 30, 2009 | Vextra Computers & Internet
Siren digital picture frame wont turn on
I had to fix my boss's digital photo frame today and it looks like it was a power supply issue. All i did to fix it was connect a usb cable AND the powersupply. The frame turned on right away. The power supply may not be able to output enough juice for powering up the frame.
Jul 02, 2009 | Siren Audio Players & Recorders
Dark pictures
All photo editing must be done on the computer before transferring the pictures. The frame will only display your images, not edit them.
Jun 06, 2009 | SmartParts SP15MW (092566981886) Digital...
This is not designed to plug into your computer. The device has no memory to store photos or music. You have to copy your photos onto a USB thumb drive or a NON SD memory card.
Feb 14, 2008 | Computers & Internet
Missing instruction booklet
I don't know where to find the instructions online, perhaps there is a website on the back of the box at the bottom in VERY small print. However, having just purchased one as a gift for my dad (a Kodak), this is what we did: Plugged it in, went to menu to set up how long between each shot, full view or adjust to fit, and then we inserted the sd card with the photos on it. It began working at that point on it's own. We also could use a jump drive. Hope that helps.
Dec 22, 2007 | Baby Gear
Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
559 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
