Question about Denon AVR-787
How to hook up Denon 787 2 smart TV - Denon AVR-787
Posted by Tony Lomanaco on
Franco Dosil
    Top Expert:
  • Denon Master
  • 10,535 Answers
Posted on Oct 03, 2019
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
I have a Denon AVR - 391 receiver and was wondering the best way to connect my CD player to as there is no provision for CD player
Sure it does:
http://www.retrevo.com/support/Denon-AVR-391-Receivers-manual/id/23705bh449/t/2/
Analog RCA cables go to anything available: DVD; SAT/CBL; DOCK
and/or
Digital audio goes to whatever is available: COAXIAL (SAT/CBL) or OPTICAL(TV)
Jan 09, 2011 | Denon AVR-787
We have our subwoofer hooked up to our Denon AVR-787, but not getting any sound from it. I'm sure it's some knob we need to turn or button to push.... All other speakers are working Help?! We're not...
press setup/configuration on your remote you'll get configuration menu, then goto 'speaker configuration' check if the subwoofer is on, check that front speakers and others are set as small. There also could be subwoofer mode settings, remember current setting and try to change it.
Jan 08, 2011 | Denon AVR-787
No sound from speakers connected to 787 including tuner
Try using your headphone, if the sound comes out, it means no problem with the pre-amp, then the problem is power output
Jul 02, 2010 | Denon AVR-787
Can PS3 go to receiver but not to TV if reciever hooks to TV?
Sounds like you just want audio I would just use the optical audio from the PS to the Denon and assign and input and you;ll have PS video and audio on your tv and just audio at the Denon
Feb 18, 2009 | Denon AVR-4306 Receiver
Speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Feb 01, 2009 | Denon AVR588 Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Hook up question
make sure on the ps3 you have the audio output setting to the optical wire and not the hdmi. im not sure about the xbox
May 09, 2008 | Denon AVR-787
Denon AVR-787 Logo
43 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
